Results 1 to 17 of 17
    Hope Vision 4 = 4400 lumens Mad
    I dont really know why but it seemed too good a chance to miss
    Bought a couple of Hope vision 4`s with out working batteries so wondered what it would be like if I converted one to 15 volts and so could run the 4 new XML U3 Leds I installed in it at the full 3 amps .
    just got it finished and waiting for nightfall to see if it is an improvement Mad yes :twisted:
    Reputation: gticlay's Avatar
    Um, pics por favor?
    "It looks flexy"
    Also, that's a really fantastic looking lighthead. So a standard XML 4-up fits in there with what driver? I'm ready for a new build
    "It looks flexy"
    Quote Originally Posted by gticlay View Post
    No its a bit more complex than a standard 4 up
    these pics are from an earlier one as I didnt take many of this build
    Driver is a B3Flex at the full 3 amps until I find it overheats like crazy
    The firewall is nice and thick and as space is tight I milled some away leaving the post for the B3flex
    series`d up the four leds
    new switch and connector in the back plate
    ready for the beamshots when the rain stops
    OK, that's really awesome. Too bad it's a pita to build. I wish someone would make an XML 3-up like the various XPE and XPG lightboards. I could see you (and others) making some rad 3 and 6 lights.
    "It looks flexy"
    No its really an easy build and there is just enough room for a b3flex without the milling
    and the Hope optic gives a nice beam with the XMLs .
    nice job troutie, I love reading your retrofit builds. That light will really surprise people when you turn it on. What was the original output, ~800lm?
    Quote Originally Posted by troutie-mtb View Post
    Well, I've already located one in chilly Alberta, BC. If the guy would come down about 50% on his price and ship to the USA I might have to try one.
    "It looks flexy"
    Beamshots
    OK its not a mega thrower but does go far enough
    beam shape is very tasty with no hotspot just a nice trail light for the bars
    Its so nice that it will be on my bars for this winter but not too sure how often full power will be needed
    Get hunting for old and busted vision 4 light heads
    that looks like a perfect beam for a bar light - lovely'n'smooth.
    I reckon if you take all trouties images and animated gif them, it would be like a scene from The Time Machine
    Cheers
    WeLight
    Cutter Electronics Pty Ltd www.cutter.com.au
    @ Welight
    Video beamshot of the beastie out with the Lumenhound
    HOPE VISION 4 TROUTIED UP TO 4400 LUMENS - YouTube
    @ Welight
    Awesome !!!
    phuuuu troutie, you are a genious modder!
    I have a complete working Vision 4 at my desk........now considdering to mod *g*
    ..just ride...
    Troutie,
    Why not use the HBflex and a 7.2V pack? http://www.taskled.com/leds/hbflexuni3_v1.00.pdf
    On page 6 of 30, there's a table that shows 7V to drive 4 XML. Would like to be able to use the packs I have now if I end up trying one of these. Also, better to use the square or round stars? I see you had both. Did you thermal tape them to where the old LEDs were?
    "It looks flexy"
    Dont think there is enough room for a HBflex but worth looking at to see.
    I use the 10 mm Square XML boards as a little thinner and the fit is better though have used both you need to keep your soldering as low profile as possible to avoid fouling the optic
    20 mm boards are doable too .
    Epoxy is used to fix the leds to the posts and the optic is used to align them up.
    Not yet done the tidy up but am sure the bezel is kicking around in the mess I am home alone this weekend so will be getting the shed sorted.
    Thanks for the note on the bezel. Crossing fingers...
    I have a Hope en-route since it doesn't require machining. Thinking of all my options at the moment.
    "It looks flexy"
