Results 1 to 18 of 18
    Mar 2011
    Hope Vision 2 mk1 upgrade help
    i have a complete hope vision 2 mk1 set of lights with a dead micro switch on the board
    i was not very satisfied by the output of my light before the switch packed up (lumen envy) so i want to upgrade the unit whilst repairing it.
    my plan is to use
    2x http://ledsupply.com/creexpg-w417.php - LED's
    2x http://ledsupply.com/10507.php - optics
    i want to drive these (or similar) from the hope 7.4v li-ion batteries.
    can anybody recommend the the right PCB to do this ?
    the PCB does not have to fit inside the unit as I am planning an addition to the back of the led mount board / heat sink.
    is there a better LED set-up to use Lumen wise?
    I'm in the United Kingdom which may affect supply and so component decisions
    any help / opinions / suggestions appreciated
    Reputation: HEY HEY ITS HENDO's Avatar
    did you take into account shipping costs
    import charges/vat if buying from the states??
    try here, ....http://www.led-tech.de/en/index.html
    ...Scun.thorpe, UK
    hi
    you will get stung ordering from led supplys well not them selfs but fedx shipping.
    thwang
    May 2010
    What about a twin XM-L conversion?
    Mar 2011
    thanks guys
    latest plan revision
    avoid buying from the states!
    use a pair of cree XM-L
    http://www.led-tech.de/en/High-Power...4_120_170.html
    i think i can use the original optics with these which is great
    now to best drive these from the 7.4v li-ion battery what should I use current regulating device should i use ?
    Try lflex, but keep it cooled.
    maybe a helpful link for our new forum member mr Toaster!
    here it is... http://www.taskled.com/index.html
    ...Scun.thorpe, UK
    Sorry! Haven't noticed it was his first post :S
    Reputation: yetibetty's Avatar
    IRONCROFT, don't forget good old lumitronix, they never let me down and I'm in the UK.
    http://www.leds.de/en/High-Power-LED...gh-Power-LEDs/
    Mar 2011
    cheers folks
    As much as I can gather the lflex driver seems to have everything I'm looking for so.........
    just to check
    if I use 2 X cree XM-L wired in series I can drive them using a lflex driver ( http://www.taskled.com/techlflex.html )
    has anyone in the UK bought one of these lflex drivers?
    what do we think about an old computer CPU finned heat sink in full airstream on the handle bars for the driver? got to be more than enough right?
    yetibetty, do leds.de supply with the LED mounted to the star PCB or just with them?
    if they don't come pre-mounted then I'll get the LEDS from led-tech.de as it states that they can be supplied mounted on the star PCB's
    I'm all for minimising soldering if possible.
    and finally thermal glue
    should i get ArcticSilver thermal glue?
    ( http://www.leds.de/en/High-Power-LED...e-2x-3-5g.html )
    or is there something better / just as good and cheaper?
    once again much thanks for any help
    May 2010
    Would there be an advantage of using say a h6flex instead?
    H6flex is a nice driver but its bloody huge and a fair bit more expensive. Using 7.4v battery with 2 x XPGs/XMLs the Lflex will be great.
    Ironcroft, I'm in the UK and I've got a couple of Lflex's. Got one driving a 2 x XML helmet light from 7.4v using Ledil LXP RS lenses.
    Lots of light but overheats my housing at anything over 2A. Might re-deploy the XMLs to a bar light (which is what they were originally bought for) and replace with a pair of XPGs driven at 1.5A originally bought for the job.
    From memory the Hope 2 is a neat little lamp but doesn't have huge surface area so you might have to be realistic about how much power the heatsink can dissipate. However, even 2 x XPGs at 1.5A will be a big improvement.
    The last time I bought from Lumitronix they had various mounted on MCPCB options. When you find the LED you want then click on" shape".
    Mar 2011
    Thanks for all your pointers
    Ordered the XML's + consumables from the Germans
    emailed TASKLED
    Going to knock out a heat sink extension for the LED mount on the lathe tomoz lunchtime in preparation. I'm planning on using thermal compound at every joint all the way to the bars to loose a wee bit of heat that way, and if (when) all this fails to lower the heat enough there's nothing stopping me TIGing an extension on the back of the light.
    Contemplating a nice ali housing for the lflex and switch too watch this space........
    Thanks again
    Mar 2011
    I'm now the proud owner of a 1950 lumen (theoretical) bike light
    Lflex is programmed in UIB2 multimode
    The light housing gets warm fairly quickly if left on high when stationary but is fine if pressed down to a low setting when stopped.
    really impressed with the user friendly-ness of driver operation and programming.
    a photo of the set-up before final tiger seal waterproofing,
    <a href="http://www.flickr.com/photos/57278737@N04/5632176719/" title="compleated unit not seal yet by adam.haycroft, on Flickr"><img src="http://farm6.static.flickr.com/5227/5632176719_d4aec252d1.jpg" width="375" height="500" alt="compleated unit not seal yet"></a>
    and after when installed on the bike.
    <a href="http://www.flickr.com/photos/57278737@N04/5632178235/" title="setup on bike by adam.haycroft, on Flickr"><img src="http://farm6.static.flickr.com/5222/5632178235_df7398ab16.jpg" width="500" height="375" alt="setup on bike"></a>
    I've only got a phone camera but i'll be posting in the beamshot thread when i can get a friend with a nice SLR out in the dark.
    ...nice one!! turned out pretty neat
    am liking the Lflex housing, does it get warm at all?
    ...Scun.thorpe, UK
    Nice one.
    I have always loved the Hope Vision 2 MK1 housing, good to see it going to good use.
    Mar 2011
    Cheers folks,
    hendo the Lflex housing stays pretty cool the whole time.
