• 10-14-2012
    ahorton
    Help me tweak my 2x 18650 waterproof holder
    I've been making a bunch of these 2x18650 waterproof holders for headlamps and they work really nicely. The downside is that they were really hard, time-consuming, and expensive to make (something like $50 per case).
    So I'm looking into getting some more professionally made in a bulk batch (more like $20 per case). Before I drop the money, I thought I should tweak the design so that it can be easily mounted on a bike frame.
    As you can see, it's made up of two parts:
    1. A piston carrying the cells, contacts, and sealing oring,
    2. An oval-shaped box with mounting lugs.
    On the headlamp, the mounting lugs are screwed to a head-shaped bracket (through which the elastic is fed).
    At first I thought I could replace the head-shaped bracket with two C-shaped clamps which would bind to a bike's frame. Then I thought that it probably shouldn't be held too rigidly because the impacts will eventually crack the plastic.
    So now I'm leaning towards:
    - a single C-shaped mount (to match the round tube of the bike's frame),
    - rigidly screwed to the box,
    - possibly rubber-lined on the frame-side,
    - and then wrap some double-sided Velcro (One-Wrap) around everything
    - (holding the box and the bike frame together).
    Velcro is already used to hold the piston in the box, so it's no hassle to just wrap an extra piece around a bike frame. I initially chose Velcro because I wanted a design that:
    - had very few parts to break when bashed around the bush,
    - was easy to use with heavily gloved hands (no screws or fiddly latches),
    - was very lightweight,
    - and was easy to manufacture.
    Any thoughts? Is there a better way to safely attach a small box (approx 100 x 45 x 25mm) to a bike frame?
  • 10-14-2012
    Toaster79
    Something like this maybe. This would be the main part of the container with the cover of the same shape and two screws holding both parts together. Velcro loop strap through the openings on the sides of the fatter bottom part of the holder in this view. All made out of plastic so no seals would be needed if the screws are tightened with a little bit more force.
  • 10-14-2012
    Ofroad'bent
    Don't forget the segment of the market that wants to mount this on the helmet.
    A shape that can accommodate helmet and frame mounting would be excellent.
  • 10-14-2012
    troutie-mtb
    Can we see the other side of the outer case please.
    not many bikers would want to clip a C type clamp to their painted frame specially when it gets covered in gritty mud
    and also the differing tube diameters
    a simple velcro strap and some cushioning IMHO and it would fit a helmet too
  • 10-14-2012
    Cheers!
    I think typically people who will buy these will be having setups that consume a lot of current. On a frame mount, 4 cell versus 2 cell is insignificant to me. Since I don't have it on my helmet or jersey bouncing around.
    I think the 2 cell holder as is would appeal to helmet and jersey people for headlight lamps. But a 4 cell would be more attractive for handlebar use.
    Will the holder fit protected cells? Or unprotected? Does the holder have built in protection board for the cells?
  • 10-15-2012
    ahorton
    Toaster, your suggestion is similar to what I'm imagining. It'll be very easy to attach a bracket to the box that makes it look like what you've drawn. I'm going to leave the sealing design in place, since they get used underwater a lot (mainly kayaking, but I went surfing once - and only once!).
    Attaching it to a helmet is already very easy. The box attaches to a headband bracket which can be zip-tied or velcro-ed to a helmet. Some people have pestered me to make a clip-on system so that the headlight can go on and off the helmet during a multisport event. So that's next on the todo list.
    On the left is the box that you see in the photo above. The right is a more recent version.
    I agree that a 4-cell would be better in many situations, but right now I want to get the 2-cell into production. I have some ideas in mind for both 4 and 8 cell designs. I need at least 4 cells to power one of my headlights and I want to use individual 18650s instead of custom packs.
    The present design takes 18700 cells. I wanted to be able to fit in the bigger XTAR 3100 (Panasonic) cells since I like them and they're the biggest cells I've come across.
    There's enough room in the piston's head to drill a 12mm hole and fit a small momentary switch, though this requires a thinner (say 12mm) velcro strap to hold it closed. A very small driver (eg, 4xAMC7135) could be squeezed into the head, but it'd be fiddly work and there would be no thermal transfer for it.
  • 10-15-2012
    Cheers!
    Very nice.
    What are you using for the cable gland? Are they planning to come prewired or as a kit for DIY assembly? Since you said they can fit bigger XTAR 3100 (Panasonic) cells, I'm assuming you have no PCB for cell protection in the design?
  • 10-15-2012
    ahorton
    Initially I used a brass cable gland with M8 thread, but now I just flood the inside of the piston's head with a low viscosity glue. It's extremely strong and water tight. A large radius fillet (bell-mouth style) prevents the cable from bending sharply at the exit.
    It doesn't have a protection circuit, but one could be installed in the piston's head before flooding it with glue.
    I don't have any specific plans for selling them. The high cost and effort previously made it unfeasible, but they might get cheaper now. Kit or assembled will both be possible if I end up selling them.
  • 10-16-2012
    Hack On Wheels
    I don't have anything very useful to add, but this looks awesome!
    I'd definitely be interested in some if you get these made.
  • 10-16-2012
    troutie-mtb
    Ash
    When and if you do a mass produced double then I will have a few off you .
  • 10-16-2012
    gticlay
    Dude, I want one!
  • 10-18-2012
    ahorton
    Sadly, 'mass produce' is probably a bit ambitious at this stage. Making a hundred is all I can consider if I'm funding it myself.
    In my dreams, I get more than 5000 made at once. Then I set up an aluminium extrusion to make the oval shape of the outer case as well as the inner cell holder, and cast a black plastic plugs for the ends.
    Total cost for the whole thing would easily be under $5, and it would be both beautiful (annodised) and strong. It also opens up opportunities for using the body to conduct current, and they could be made to any length (though 2 or 4-cell are probably all that would be useful). ... Anyway, I have heaps of dreams...
    I'm loosely planning out a kickstarter or indiegogo campaign just to see if enough others want something like this too, but for now I just want to play with the design more and get it perfect.
  • 10-18-2012
    [jsl]
    I was just going to suggest you set up a kickstarter project!
    The oval shape would be nice for carrying the battery in your pocket, but for mounting on the bike or helmet I would prefer it to be more square-ish or something like in Toaster's design.
    How about making the end caps out of some rubber-like material? That would provide some impact protection and would be easy to glue to the aluminum shell with Sika flex or something similar.
  • 10-18-2012
    mattthemuppet
    I'd definitely go for the lightest weight you can as weight on the helmet can be quite noticeable. For shape I'd stick with something that is slightly concave on at least one side so that it sits on a frame tube easily, but without any stickyout bits that would snag on a jersey pocket or make mounting to a helmet difficult.
    Some way of retaining a single velcro strap would be useful - could be something as simple as a screw + washer that would thread through the strap into the middle of the case.
    A supplied stickysided rubber pad(s) would be useful too, for the frame mounters.
    Can this be wired up 2S1P and 1S2P? Both set ups would be very useful.
    Does it need the velcro strap to keep it closed? If there are matching grooves for the o-rings in the housing then 2 o-rings should provide enough force to keep it together.
    I like the idea of there being space for a PCB in the head of the holder. Would there be enough space to tuck a balance wire in there too? I know I can take the cells out to charge, but it would be nice to have the option, especially if you offer a 4 cell pack.
    If this is set up for protected cells up to 70mm long, are the springs long enough to make good + reliable (ie. no bump disconnects) contact with unprotected cells?
    I'd seriously consider one of these holders, even up to ~$30, just for the ease of assembly :)
  • 10-18-2012
    ahorton
    Lots to respond to...
    Lightweight is definitely essential. I've struggled with this because it's very easy to make the case with thick walls, but I wanted thin to save another 20g on the head. Doesn't sound like much, but it all adds up.
    I also would love to have a concave side, but it adds other problems. A minor problem is that the cell-holder (or piston) can only have one leg (or none if you take toaster's design). The bigger problem is that orings nolonger work well on the inside. So the seal becomes some sort of gasket (I tested with some custom silicone ones) that presses on the end profile. This works fine if you keep up the pressure. So you need a reliable and strong latch (eg over-centre). I much prefer the Velcro because (in normal use) it is 'unbreakable'. It also only takes a tiny force is to keep the piston inside the case. Even if the piston and box move a few mm wrt each other, the seal is maintained.
    ** An interesting idea, is to get an oval extrusion, and with a multi-part mandrel, crush the tube so as to get a concave part and still hold the oval at the ends (where the seals are).
    As it is now, 1S2P and 2S1P are both possible.
    A balance plug would be tricky without a design change.
    with a 70mm cell it's very tight, so it still holds a 65mm cell.
    The Velcro is needed because the chamber gets a slight positive pressure and tries to push the piston out. It's only slight. It's very satisfying to know that the seal is working!
  • 10-19-2012
    phburns
    Nice design. How about making some silicone molds molds from your prototype and then casting. I've found that the expense is making the pattern, the casting resin per part is pretty reasonable, and durable. I've used several different suppliers and have been satisfied with my results, there are many choices, here's a couple;
    Molds OOMOO® 25 and OOMOO® 30 Silicone Product Information | Smooth-On
    Pourable Black Plastic Casting and Finishing Smooth-Cast® ONYX® Deep Black Resin
  • 10-19-2012
    ahorton
    Great idea! In fact I've been doing that for a while now.
    I've been through more than 10 different polyurethane formulas (including the S-on Onyx which I found too brittle) and eventually settled on S-on 310 for a variety of reasons.
    The custom plastic parts in these headlights were all made by this method.
    For most parts it works excellently, but the battery case turned out to be a real challenge. After several masters and many moulds, I found I could have any two of 'consistent', 'quick and easy' or 'good quality'.
    With an aluminium extrusion, the plugs and cell carriers will be really easy to cast.
    NB: For those interesting in making custom plastic parts this way, I have a few bits of advice:
    1. Invest in a pressure chamber
    2. Invest in a vacuum degassing chamber
    3. Since you've done the above two steps, skip the OOMOO silicones and go straight to the Mold-Max or Platinum cure ones. They perform better and last longer.
    4. Get excellent masters. The polished nylon parts from Shapeways are great, but machined masters are better.
    5. Spend a lot of time getting your moulds right (do not rush this stage).
    6. Don't skimp on the Silicone. Use heaps more than your wallet wants you too.
    7. Use a slow-cure polyurethane (eg S-on 310)
    8. Work in a low-humidity environment
    I started out trying to save money and time ... and got what I paid for. When I eventually invested about $500 in all the better gear, I started getting great results.
  • 10-19-2012
    Hack On Wheels
    That's a slick looking headlamp; I'd be interested to know more about that one!
  • 10-19-2012
    phburns
    I can imagine the thinner-wall large volume castings are a PITA, agree it would be easier to go with an extrusion with plugin caps. Nice work!
  • 10-20-2012
    ahorton
    That headlight is designed more for walking. It's not so good as a bike light (though I do use it).
    Anyway, back to design options for the battery case:
    The 4-mounting-posts design I showed earlier is ideal for some applications (like my headlight), but I'm wondering if a dovetail rail might be more universal. As bonuses; it spreads the mounting forces more evenly along the length of the case and is extrudable (for later on).
    Here are some quick sketches of possible cross sections of the case + matching rails-mounts.
    The mounts could be made from a cast plastic, or a silicone/rubber. With a good friction fit they probably wouldn't slide, but could always be secured with a single lateral screw halfway along their length.
    Along the top row (numbered from left to right):
    Numbers one and three, if made from a rubber, could be flexed to allow mounting without actually sliding it along from the end. By contrast, number two can only be mounted by sliding axially, but the final mount would be more secure.
    The fourth represents a simple tube which requires much bigger mounts to surround the whole thing. In that case you'd probably only use a couple of 10mm thick mounts, rather than a whole rail.
    On the bottom row, I just demonstrated a way to combine two back-to-back and compared it to how a real 4-cell case might look. Obviously it ends up about 20% bigger in one dimension.
  • 10-20-2012
    ahorton
    Some other concepts that I considered:
    A T-slot design or a ribbed-slot design (to accept machine screws or a strip of similarly ribbed rubber/plastic).
    I think I still prefer the dovetail style. It can always be drilled and tapped if a screw-mount is desired.
  • 10-24-2012
    zemike
    Well, this is an interesting proposition.
    I think that a similar design was made by Magicshine in their crazy LCD battery pack. For a bike I suggest to make an aluminium extrusion with machined eyelets for Velcro straps and plastic end caps with sealing gaskets. And 4 cells is the bare minimum.
    I think that we can cooperate on this project. PM me if interested.
  • 10-24-2012
    gticlay
    Yeah, what's the headlamp? I want to find something for my wife to run with.
  • 10-24-2012
    ahorton
    For the price, the Magicshine case is great. Yet another reason not to build a 4-cell section in my mind. Though I do think that a double-length 2-cell section (4 cell total) could be nice and practical.
    Another reason against a 4-cell section is that a 50x1.6mm or 50x2mm aluminium tube is fairly easy and cheap to buy and fits 4 cells nicely enough for the diy guy.
    One thing that put me off the Magicshine style, is that I want it to be quick and easy to swap in fresh 18650 cells. Even if I modified a Magicshine case to have a 4-cell holder with spring contacts, the seals require screwing it together.
  • 10-26-2012
    Cheers!
    This to me is the nicest 4cell 18650 case. It's so nice, I convinced Kevin on candlepower forums to just sell me the case with the holder and cable gland. Would fit perfectly in the back pocket of a cycling jersey because it is a flat 4 cell config instead of a round config.
  • 10-26-2012
    gticlay
    How much was it?
  • 10-27-2012
    ahorton
    Yeah that's a great case but for a different application. Nice and simple and very strong.
    I'm going for the ultra-light approach with a head-shaped bracket in order to eliminate bounce while running.
    Even Kevin acknowledges that his battery case is heavy and more aimed at cavers.
  • 11-09-2012
    zemike
    For a bike weight is a lesser concern.
    Here are my proposed requirements:
    body made from an aluminium extrusion with plastic end caps and sealing o-rings
    2 cells side by side
    available in different lengths: 1, 2 and 3 cells long
    different battery configurations: 1P2S, 2P1S, 2P2S, 1P4S, 2P3S, 1P6S
    quick battery swaps are not required, because it is easier and safer to swap battery packs
    fixing to the frame by Velcro straps
  • 11-10-2012
    NovaNath
    Hi. Have you considered dip-moulding as a manufacturing process for your plastic parts?
    If your capable of machinig aluminium, with a little advice you would be able to make your own tooling.
    Find the right factory and they should be able to do samples and short production runs.
    I hope this doesn't come across as spam (my first post), but as you might imagine I work for a dip moulding manufacturer (toolmaker) and have had experience of getting my own 18650 holders moulded (my own project stalled).
    Good luck with the development work; the holders that you've made look very professional!
  • 11-11-2012
    ahorton
    Thanks zemike. I've got a pretty good universal system that can allow any of those configurations.
    NovaNath, I was under the impression that dip-moulding was just for flexible plastics. The first 50 headlights I sold all had dip-moulded (PVC + some elastomer) cases. They were nice and waterproof, but you couldn't swap the 18650s so I moved away from them.
  • 11-11-2012
    NovaNath
    You are right; flexible and semi-rigid (there are a myriad of grades).
    We produce a lot of custom shoruds of one sort or another. The nature of the material is to self seal and you can cut grooves in the tooling to make stiffening ribs in the moulding/add internal detail.
    I was thinking that if you had a V profile on the lower back part of the sleeve/box (with horizontal or vertical slots to maintain shape for batteries-), this could deform slightly as you do the velcro up tight, and form to the shape of the bike frame tube. (Velcro would wrap round the outside of box). The tackyness of the moulding would help hold it in place.
    The more recent smooth version that you pictured in post #6 would translate well into a dip moulding, but because the moulding would come out with fairly uniform wall thickness, you would need to be creative with your fixings for the lugs you use to attach the loops/straps.
    I do a lot of tooling design, so this sort of ticklies my interest! :)
    I can model up an example if my words don't make much sence? (i'm a picture thinker)
  • 11-11-2012
    ahorton
    Thanks for the offer, but I think I'll stick with the rigid design.
    As well as cyclists, I make these things for cavers and swimmers, so it needs to be dive-proof.
  • 11-11-2012
    NovaNath
    Ahh, I'd missed that.
    I'm not sure i'd want to rely on a dip moulding when fully immersed either.
  • 11-13-2012
    mtomass
    hi ahorton, you have a sample of your battery holder?
    I'm interested for a my project...
    please contact me.
  • 11-13-2012
    ahorton
    All the good samples have been used I'm sorry. New ones are currently being made. I'll let you know when they are ready.
  • 12-20-2012
    SASniper
    Hey!
    First post on the forums after some time lurking around.
    I've just finished up my first easy2led helmet light which worked out really well :D but now that's done I gotta get a nice battery holder sorted. Obviously I've toyed around with joining cells together in single holders then plasti dipping them (or similar) but honestly your work has caught my eye! Have you had any progress with manufacturing?
    Cheers,
    Steven
  • 12-20-2012
    roxtar
    Originally Posted by gticlay View Post
    How much was it?
    What he said and who's Kevin?
  • 12-20-2012
    Cheers!
    I bought the last one. $60 USD + shipping
  • 12-20-2012
    Cheers!
    Ever thought about social media?
    Kickstarter
    I learned about them via backing 2 guys for brake rotors:
    SiCCC Bicycle Brake Rotor: Silicon Carbide-Ceramic-Carbon by Kettle Cycles — Kickstarter
  • 12-21-2012
    borrower
    Kevin Kavelight on CPF link
    Kevin on CPF:
    Kavelight P60 Headlamp
    As mentioned, his beast is a bullet-proof unit, with weight being a secondary concern.
  • 04-02-2014
    Magnum9
    Re: Help me tweak my 2x 18650 waterproof holder
    Thread dig, did you ever get these holders into production?
