Results 1 to 2 of 2
    Help me rebuild my L&M battery
    Would someone mind helping me rebuild the battery for my ARC? I'm capable of doing the soldering but someone will need to help me choose/source the batteries and give me basic direction on what to do. I believe what I have is a 10.8vv NiMH (its the skinny one with the rubber cover) and I would like to make something with a longer run time.
    Do It Yourself
    Reputation: Homebrew's Avatar
    From the wayback machine for building NiMH batteries:
    DIY Lights: How to build your own battery...
    The info on the cells are still valid. You want nine 4/3A cells. Top capacity available is 4500mAh but you can get 4000mAh at a substantial discount at the link below. There is also a weight penalty.
    4/3 A SIZE: DIA 17.0 mm X HT 66.0 mm
    PART NO MFR COMMENT MAH GRAMS OZ PRICE View Cart
    HR-4/3AUX Sanyo Ni-MH 3800 52 $ 4.95 Buy
    HR-4/3AU Sanyo Ni-MH 4000 55 $ 5.95 Buy
    HR-4/3AU SALE
    WITH Solder Tabs
    Limited Supply Sanyo Ni-MH 4000 55 $ 4.00 Buy
    4/3 A SIZE: DIA 18.0 mm X HT 66.0 mm
    HR-4/3FAU Sanyo Ni-MH 4000 62 $ 6.50 Buy
    HR-4/3FAUX Sanyo Ni-MH 4500 62 $ 6.95 Buy
    http://www.batterystation.com/nicads.htm
    So just tear that old battery apart (it's already broke so don't worry about breaking it), wire it the same way and rewrap in the plastic cover with RTV silicone to seal.
    Long Live Long Rides
