Results 1 to 2 of 2
    help with driver
    I burned out the driver in my cheap 2 XML light. I have verified the LEDs are fine with a bench supply. I ordered a few of these drivers
    https://www.fasttech.com/p/1143104
    I can't find any documents on the site.
    I tried getting rid of the flashlight contact pad and wiring my battery (11v L-ion) connector to it, but I can't get it to work.
    How do I wire this thing up with a switch to get it to work? The switch i have is momentary, normally open.
    Thanks,
    Captain
    I don't have experience with that particular driver, but most drivers of that style switch modes by interrupting power going to the driver board from the battery. So you would connect your switch between the battery and the driver board.
    Most flashlights have an on off latching switch and mode changes are done by pushing the button partway. I'm not sure your switch will work. You also need to make sure that whatever switch you use is rated for enough current.
  1. Xd driver on ck hub
    By fxrextreme in forum Wheels and Tires
    Last Post: 04-01-2016, 09:40 AM
  2. X9 Hub XD Driver help
    By hbar314 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-24-2016, 10:48 PM
  3. 2 led 1 driver vs 2 led 2 driver?
    By machine4321 in forum Lights DIY - Do It Yourself
    Last Post: 10-31-2014, 03:13 PM
  4. Driver 8 on CL now
    By MtnBikinDude in forum Santa Cruz
    Last Post: 12-14-2011, 12:51 PM
  5. Driver 8 help
    By grahamski420 in forum Santa Cruz
    Last Post: 07-07-2011, 05:53 AM
