Results 1 to 3 of 3
    Has anyone tried this Cutter Kit?
    I'm curious if anyone has tried this Cutter MRE 11 kit?
    http://www.cutter.com.au/proddetail.php?prod=cut947
    If so what are the pro's and cons? Any beam shots?
    Quote Originally Posted by Dave T.
    Cutter MCE MR11 Kit
    Dave, I've built a few MCE lights.Fraen reflector comparisons
    The last one I did was not a Cutter kit but used the same MCE and Narrow Fraen reflector.
    I did find that the lens had an unbelievable amount of throw but not much fill on the sides.
    Sort of like a Torch type beam.
    My intent was to make a double MCE helmet light using those same reflectors, but I found them a bit too narrow for my taste. I mixed it up with a frosted wide lens and it was better.
    You still might be OK with the kit, but you might try also ordering an IRIS lens from some of the sellers at CandlePowerForums.
    Bram should have a few in stock, plus any other lenses that you think may work.
    In lieu of this kit you may want to try and do an XPG kit, which should put out more lumens than the MCE. Both kits should fit the same housing.
    I built one a few months ago and found that the quad setup with a Cute Narrow lens is quite good. I like the pattern a lot better than the Fraen/MCE combo.Quad XPG light
    You can do it in a quad or triple setup as well,either way for a helmet unit it's hard to beat.
    Not quite as much throw but it's more usable and has better fill. GT4 and Cute 4 beam shots with bonus
    Good luck and post when you're done.
    Eric S
