Poll: What holders do you want?
Results 1 to 16 of 16
    Group buy of 18650 holders for EU
    Thanks to cosmoworks for pointing out the new Batteryspace holders for 18650 cells with PCB
    http://www.batteryspace.com/Li-Ion-1...installed.aspx
    Due to the exorbitant shipping cost I propose to organize a group buy of those holders for us, European bikers (and Canadian too).
    I will buy a large quantity of those holders and mail them across Europe. I think that I can arrange the same price, as Batteryspace (I will try to negotiate a wholesale price), for example - €15 for a 2P2S holder + mail expenses (around €7-10 per package).
    What is your opinion on this idea and what holders do you need?
    Also, I think that other countries outside of EU can join in this group buy.
    Nov 2008
    1x 2s2p
    Awesome, might be interested in more holders but for the moment you can count me as a solid order for one.
    I coul'd use two pieces 3S1P
    According to the distribution of the votes, I should order 45% 2S2P, 22% 3S1P and 23% 4S1P.
    45 + 22 + 23 = 90%. What would you do with the rest?
    My bad!
    45% 2S2P, 25% 3S1P and 30% 4S1P
    Nov 2008
    Is there not much interest in these? I assumed there would be many who would be up for this?
    Anyway im currently stuck in the Canary Islands for a bit, hoping to fly to Madrid on wednesday, Dublin on Tednesday and then on to Stansted so if I dont respond to any PM's or anything thats why.
    On a positive not some awesome riding out here!
    2 No 3S1P Please!
    Dec 2009
    I might be interested but I don't understand how best to configure batteries for a bike light project. I have been following Quazzle's thread and have been drooling over some of the ingenuity and lights but know as much about electronics as would fit on the last character on this line.
    (Electronics For Dummies doesn't arrive for days)
    I understand that Series boosts the output but why would you have 3S1P what does that do for output as opposed to 2S2P for instance? sorry if this is the wrong place to post
    Nov 2008
    Zemike: can i also order a 4S1P along with the 2S2P i have alread ordered
    dickiebeau :in series voltage is increased, ie.
    1S 3.7v
    2S 7.4v
    putting them in parellel, increases capacity, ie.
    2S1P 7.4v, 2000mah
    1S2P 3.7v, 4000mah
    both of these configurations obviously have the same total energy since they are both comprised two cells. Voltage x Capacity = Energy.
    Not been reading much about quazzles module but i assume its output is regulated so light output should be constant no matter the battery configuration, you just need to make sure that input voltage is within the allowable range, im pretty sure the high end is around 9v so that would limit you to a 2S configuration. Also remember that 18650 cells have a 4.2v peak when fresh of the charger.
    Edit: Voltage Range............DC 4.8 - 9.5V
    Yes you will be limited to a 2S configuration, 3 is too high (12.6v peak) and 1 is not high enough.
    dickybeau
    For the Quazzle triple you would need 2S1P for minimum weight or 2S2P for maximum runtime.
    zemike,
    How much would the shipping be to the land downunder, seems crazy that its cheaper to go from states, to EU to Aus, but im sure it is, damn battery space shipping.
    Let me know and ill be keen
    Stu
    Defcon Cycles - Brisbane Australia
    stu44
    If I am not mistaken, the shipping cost in a small packet to Australia will be around 15 for up to 3 holders.
    Update: looks like it is possible to arrange this group buy, but it will consist only of 2S2P holders.
    Reputation: flyxaos's Avatar
    I see they have pcb's built on. Can protected cells be used in these holders? That is what I have.
    Quote Originally Posted by flyxaos
    I think that it is possible, but it will depend on the cut-off voltage of the battery PCB (which PCB will cut-off first)
