Results 1 to 30 of 30
    Sep 2013
    First triple xml light
    Hi this is my first light and first post. Am amazed by the lights ive seen on here and as being a machinist (still alot to learn as im 25) i thought i would start my own.
    im building a triple xml light with a h6flex driver and this is what i have done so far...
    Sent from my iPhone using Tapatalk - now Free
    Reputation: stuflo's Avatar
    Mar 2011
    Looks nice. Is that done on a cnc lathe with live tooling then?
    what size board and optics have you got in it.
    May 2005
    Looking nice! Only critique is it looks plenty chunky. Weight?
    Sep 2013
    Its been done on a manual lathe and manual mill. Theres still alot of machining to do yet so it should be abit slimmer when finished.
    Sep 2013
    The driver is 33mm and optic is 35mm, not sure about weight yet.
    Mar 2011
    looks very nice.
    want to try an xml build but its just getting round to it and it looks like i'll have to use a 35mm optic. been trying to find a triple setup on a 20mm board for carlco type optics like my xpg build.
    May 2005
    Quote Originally Posted by stuflo View Post
    I doubt that if an XML fit triple optics that small that the beam would be worth a darn for biking.
    Mar 2011
    That seems to be my thoughts to Vancbiker.
    Just wanted to try and make a real small 6 up.
    May just try and design up 2 small lights 3up each and the driver in one of them.
    holly cow, that's very impressive for a first light! I don't think you'll have much of a problem with heat there
    Sep 2013
    Thanks im hoping to get all the machining finished by the weekend, its hard work rushing on my 30min lunch break everyday. I will get some more pics up tomorrow.
    I can imagine! It would take me longer than your lunch break just to get something set up to start machining Keep up with the build photos, this is like light building by proxy!
    Sep 2013
    Sep 2013
    Just need to polish it and fit all the parts now.
    Sep 2013
    May 2005
    Ahhh theres goes some weight and gain some cooling too!
    Mar 2006
    Damn nice work! I would love to get laid and a mill!!
    "By Your Command"
    Reputation: Fourtrax's Avatar
    Mar 2013
    Nice looking light! Did you just glue in the green LED on the back? I can never tell scale from the pictures, what did the overall dimensions end up being at?
    pucked up
    That's an interesting combination.
    Mar 2011
    That light is looking very nice indeed.
    Killer b.
    Reputation: The Understater's Avatar
    Very nice indeed. Nice machine work. I suspect it won't be your last build. It's addictive.
    Posting on the basis that ignorance shared is ignorance doubled.
    ooh wow, that's a change. Ditto what Vancbiker said, it's a win win!
    @The Understater - there's never such a thing as a "last build", the universe does not allow it
    Sep 2013
    Looking good after a polish.
    Sep 2013
    I will be making more in the future! When i get a bench lathe and mill in the garage next year. I can see how it can become addictive.
    Sep 2013
    May 2005
    Nice polishing work there! Are you going to anodize it?
    Sep 2013
    I think so. Just looking for some sulfuric acid to do the job.
    Reputation: beecrazy's Avatar
    Very nicely done!
    Welcome to the addiction.... I mean forum!
    Don
    09 Specialized Rockhopper Comp 29er
    16 Rocky Mountain Blizzard -30
    Sep 2013
    Finished product!
    Mar 2013
    Excellent work! Jealous that you have access to a lathe! Is that a standard water bottle that you used for the battery holder?
    fantastic job, give yourself a pat on the back. Then go for a night ride!
    What battery is in the bottle? I bet that you could stuff and awful lot of 18650 cells in there.
    Sep 2013
    I used a tool bottle as it has a wide opening to fit the battery in. Im using an turnigy 14.8v 4500mah rc battery. Thanks for the comments.
  1. Triple XM-L light review
    By -Archie- in forum Lights and Night Riding
    Last Post: 09-01-2013, 06:55 AM
  2. Triple XML Bar Light MK2
    By brad72 in forum Lights DIY - Do It Yourself
    Last Post: 01-26-2013, 02:18 PM
  3. Kaidomain ( K/D ) Triple XPG R5 Bike Light
    By Cat-man-do in forum Lights and Night Riding
    Last Post: 01-28-2012, 02:13 AM
  4. Yet another Triple and cute light
    By troutie-mtb in forum Lights DIY - Do It Yourself
    Last Post: 11-04-2011, 01:29 PM
  5. Triple Seoul P4 LED Light
    By achesalot in forum Lights DIY - Do It Yourself
    Last Post: 08-26-2009, 04:33 PM
