Well I was very happy that Ive finished my Light and little did I know that the switch I bought from mouser is the wrong one heres link http://www.mouser.com/Search/ProductDetail.aspx?R=48-2-RB-N-BK-Bvirtualkey56650000virtualkey850-48-2-RB-N-BK-B
I spent numerous hours trying to program my H6FLEX with no luck...Emailed George from Taskled and sure enough ....switch is not momentary action... darnnn it !!!!!
can you guys help me find the right switch? links to manufc?
thank you .... I dont want to make another mistake on ordering the wrong one...
Thanks..1111
According to the itswitches datasheet you posted you need the 48-1-RB-N-BK-B.
HOWEVER - when I typed that number into the Mouser website, the product detail page is still showing the Momentary box as unchecked. I'd contact Mouser if I were you to see if they have made a mistake. You need a momentary switch, normally open (NO).
I use RP8100B2M1CEBLKBLKRED from Digikey ([URL="http://search.digikey.com/scripts/dksearch/dksus.dll?Detail&name=EG4574-ND']for red[/URL], you can also get other colours). I've used 6 so far, no problems with any of them.
thank you guys for the info.....appreciate the reply's...... So yeah apparently Mouser.com has an error on their page describing part# 48-2-RB-N-BK-B on their description page has a momentary switch....instead of saying "momentary" it should say "maintained" I reported it to mouser.com about it...not sure if they will change it though.... thanks again for the links
I think you are reading the Mouser page wrong. The line says "Momentary" with a check box next to it. If unchecked then it specifies that the switch is Maintained, if checked then it is a Momentary switch. Where the Mouser site is wrong (according to my interpretation of the itswitches datasheet) is that the page for the switch with the part number 48-1-RB-N-BK-B should have the "Momentary" box checked.
Refer to the itswitches datasheet again and you will see that the Module Type 48-1 is for a Momentary switch and 48-2 is Maintained. The Mouser website has both module types with unchecked "Momentary" boxes indicating that they are both Maintained switches which is obviously wrong in the case of the 48-1-RB-N-BK-B which is the switch that I think you need.
I hope that's clear.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
