Results 1 to 8 of 8
    Hack Racer
    Reputation: Cheers!'s Avatar
    Easy2led housing for 35mm optics builds?
    I was wondering if anyone has done any builds with the Easy2led housing for 35mm optics?
    Reputation: Fourtrax's Avatar
    Mar 2013
    I just finished a build with one. Had its maiden voyage last weekend. I'll start a thread with the build info and pics. Nothing special although I had fun building up the battery pack.
    i have one running since the 35mm housing was available - runns fine, no Problems until yet!
    ..just ride...
    Hack Racer
    What did you guys use for lenses, led, and engine?
    ..just ride...
    Whitedog, can you post some photo's?
    I'm building same light but having issue mounting my hBflex, barely fits in housing.
    I can't decide which way to run power into housing and mount remote switch.
    bflex is much smaller I know but curious how you're attaching to back plate.
    I would run a bflex but all my packs are either 7.2v or 11.1v, don't want to spend more money if I already have the parts.
    Just need to do more head scratching...
    Eric S
    I attached the b3flex with a block of Aluminium and some thermal adhesive!
    No photos this time sorry!
    ..just ride...
    Mar 2013
    See the build thread below. I also used a B3Flex and aluminum standoff from taskled. Attached using Arctic Alumina epoxy.
    35mm Easy2Led build
    Some additional pictures of the driver.
    Attached Thumbnails Attached Thumbnails Easy2led housing for 35mm optics builds?-image.jpg
  1. Easy2LED housing with external switch build
    By Ofroad'bent in forum Lights DIY - Do It Yourself
    Last Post: 04-28-2013, 05:22 PM
  2. Anyone building with the Easy2LED M36 housing?
    By adrenalnjunky in forum Lights DIY - Do It Yourself
    Last Post: 11-13-2012, 04:02 PM
  3. Easy2led housing for 35mm optics.
    By zemike in forum Lights DIY - Do It Yourself
    Last Post: 08-07-2012, 11:12 PM
  4. A bigger Easy2LED housing - comments welcome
    Last Post: 02-03-2012, 06:39 AM
  5. Looking for a 35mm housing
    By kwarwick in forum Lights DIY - Do It Yourself
    Last Post: 05-09-2011, 07:27 AM
