Results 1 to 9 of 9
    Reputation: Ofroad'bent's Avatar
    Easy DIY remote waterproof momentary switch
    I was building an Easy2DIY light with switch and power wires through a cable gland out the back, and got to thinking- i am not confident with my soldering of the finicky wire on the waterproof PTT switch I got from Easy2LED, so why not make up a switch using what I have in stock?
    I just used a waterproof momentary switch, added a few layers of heat shrink which I bent 90 degrees while warm, some Velcro, and voila!
    <a href="https://picasaweb.google.com/lh/photo/ZZ5O1l5Qb7hCNfcAUGJqLNMTjNZETYmyPJy0liipFm0?feat=e mbedwebsite"><img src="https://lh6.googleusercontent.com/-PsnaA4FZses/UTCtI58e3TI/AAAAAAAABqY/imxPJfiT3n0/s640/image.jpg" height="520" width="640" /></a>
    If I get this right, the switch button will just stick out of a helmet vent.
    neat idea. It's not like you have to put a lot of pressure on it.
    null
    I like the idea of a monetary switch– press the button, and WHAMMO, you’ve got cash!
    Sign me up! Damn you autocorrect- fixed now.
    A waste of time it is is
    Reputation: emu26's Avatar
    Nice work ofroadbent. Does it stay upright or tend to want to rotate to the side when you are trying to press it?
    No, it sits in the vent securely.
    good stuff
    Reputation: deesta's Avatar
    Here was my take on a similar use of one of those momentary switches:
    I used a strip of rubber and have some self adhesive velcro on the rubber/mating vecro on my helmet. The switch drops perfectly into one of the vents...
    Jan 2018
    Waterproof remote control
    I put a bunch of crazy lights on my Kona for night time mountain biking and tried to make it look like the truck with a dozen lights from Crocodile Dundee first opening clip with the kangaroo hunters. I have lights shining off every direction and its awesome. I'm going to get some photos to share here this weekend. I built a waterproof remote control for this and I'm making a way to mount my lights on my surfboard for night surfing also using these lights and will share some completed photo shortly as well.
Members who have read this thread: 26
