Results 1 to 7 of 7
    Easy 2 Cree red taillight.
    Not quite the territory of Dinotte, but close enough. Two in parallel off a DX 3.6v-8.4v board with 5 modes.
    Standard connectors that fit the ubiquitous Chinese lights.
    Housing is 1 inch square alu tubes, with silicone caulking as sealants to make it weather proof.
    I could've gone with momentary switch but decided against it as the driver board has memory mode, I leave it on flashing mode.
    The clip in the back of the housing is salvaged from a cheapo planet bike blinkie, attached using a single screw and jb weld.
    Attached Thumbnails Attached Thumbnails Easy 2 Cree red taillight.-img_4638.jpg
    very neat - simple but effective! You probably could have wired the LEDs in series though, red LEDs tend to have a much lower Vf than white ones (red XP-Es at least), then it'd be even brighter
    Quote Originally Posted by mattthemuppet View Post
    I tried that, it overheated very quickly, I thought about using heatsinks thermal pasted on but that just takes away from the simple clean look.
    that makes sense, there's not a whole lot of surface area there! As long as it does what you want it to do, who cares?
    A simple clean look indeed, well done.
    Re: Easy 2 Cree red taillight.
    Nice, any chance you can post a link for the board you used from DX?
    Quote Originally Posted by Magnum9 View Post
    Here you go.
    3V~8.4V 5W Cree 5-Mode Memory Circuit Board for Flashlights (16.7mm*6.3mm) - Free Shipping - DealExtreme
  1. Supernova E3 Taillight 2, what rack is this?
    By seth586 in forum Lights and Night Riding
    Last Post: 04-28-2013, 12:20 PM
  2. Best taillight?
    By Dr.Mushy in forum Lights and Night Riding
    Last Post: 11-21-2012, 09:35 AM
  3. Magicshine Taillight Meltdown
    By rearviewmirror in forum Lights and Night Riding
    Last Post: 10-07-2012, 07:44 PM
  4. Taillight attempt
    By wiggy in forum Lights DIY - Do It Yourself
    Last Post: 05-06-2012, 03:35 PM
  5. MS 900 converted to taillight.
    By stumblemumble in forum Commuting
    Last Post: 03-08-2011, 06:20 AM
