Thread: dx driver
    dx driver
    hi all
    i have these dx drivers that are battery +/- on the under side can you solder the +/- on the side as photo there are 2 solder pads G/G1 are they the battey +/-.
    cheer simon
    No. Not sure where to connect on the top of the driver, but those two pads don't work for +/- "in".
    We have some good EE types here. Hopefully one with chime in. I would like to solder to the top of the board as well.
    those both pads look to be both ground ie batt neg, as the outer ring on the other side, for positive i would say the hole in the center is when the positive passes though the pcb so the cap next to the hole in the center would be batt +
    Hope this helps, Ace
    Reputation: yetibetty's Avatar
    thwang sorry I can't answer your question but you may want to check this post of odtaxas as I think you may have the same driver: 3.6V~9V 800mA Regulated IC Circuit Board
