Results 1 to 32 of 32
    No talent hack
    Hope Drivers, how do you select one? (Newbie alert...)
    So I have sorted through just about everything in planning out a light for my handlebar except for the driver. I have spent time on diyled reading, but much of the info is pretty old by "technology standards."
    What I know:
    1. I think a 2 LED light will be enough. I want some flood on the ground up close for my peripheral vision to use and then a spot ahead to supplement my light on the helmet. I have a Cygolite Expilion 700 for my helmet and it is plenty bright for the riding I do.
    2. I plan on a simple build using 2 XML LEDs. I know the XML can be made into a good spot, but is there a better LED for flood?
    3. I really only NEED one light level. I am very happy running my factory light at the medium setting. Since the max is suppose to be 700, I would assume medium is 400-500 lumen, but there isn't SOLID info from Cygolite on this.
    How does one go about picking a driver? It seems that a Buckpuck is likely what I need running 4 18650 cells, but what am I missing in selecting which BP to use? A 3023 would be the easiest (this is obviously my first light) since it has leads on it already. How does one decide what amperage to select? I have tried searching and have found many threads about builds, but I can't find solid info about how to select.
    I am familiar with electrical basics and have done quite a bit of work on 12vdc in cars and such, but I am not an electricians by any means.
    Please go easy on me (I know I am a newbie). I have searched and read quite a bit, but I am likely missing some important info threads because I am not searching correctly. If you reply with threads to read that contain better newbie info, I am happy to read.... or responses are great.
    I am itching to start "playing" and building. Thanks for being patient with, yet again, another newbie.
    2013 Specialized Camber Comp
    2014 Trek Domane 4.0
    2015 Surly Karate Monkey Ops (the commuter)
    Buck puck easist if you have the room for it.
    "How does one go about picking a driver? It seems that a Buckpuck is likely what I need running 4 18650 cells"
    Four parallel for 3.7 volts
    Four series for 14.4 volts
    Two series two parallel for 7.4 volts
    This will also influence which driver you can use.
    Since XM-L's need to be driven at up to 3 amps for maximum output, Luxdrive BuckPucks won't fit your needs, as they max out at 1A.
    TaskLED's b3Flex would be your fancy buck solution. In that scenario, yu have to run your batteries in a 4S1P config for a 14.8v pack.
    Cheaper fancy option possibly - TaskLED's lFlex linear driver. 2 XM-L's on a 2S2P pack would be doable as long as you headsink the driver well,a nd your housing has good cooling properties.
    If you're looking for a cheaper buck driver for a build, and fancy doesn't matter, try this buck driver: T6 3-Mode Regulated LED Driver Circuit Board for DIY Flashlight (2500~3000mA 4.5~18V) - Free Shipping - DealExtreme
    buy a spare or 2 for fun, and grab a couple of these linear drivers for future projects too:
    17mm 2800mA 5-Mode Memory Regulated LED Driver Circuit Board for Flashlight (DC 3~4.5V) - Free Shipping - DealExtreme
    Oh - and narrow/flood, etc, will depend on what optic or reflector you decide to use, and what will fit in the housing you're making.
    Share some ideas on what you're planning on building and we can suggest changes or other options.
    No talent hack
    adrenal - Oddly enough, the post clears a lot up for me. Kind of puts pieces back together. I had wondered how an XML was rated for 3a and yes drivers were less (I think this bit of confusion came from reading older info about older LEDs).
    Another question about batteries. When you post "4s1p" I read "4 in series plus 1 in parallel" but when I have been looking at battery holders, the ones labeled "4s1p" only appear to hold 4 batteries. Am I reading battery terms wrong or am I missing something else.
    As for the design plan.... I am just aiming at simple. Function over form... at least on this first light. bikeled has a dual Cree led (first light on the page I see) that is made from aluminum tube. I plan on either mimicking that design or the copperhead design but for additional heat-sinking area, I have a few of the heat-sink below to use in this fun... picture one of the basic housings with the blue heat-sink split in half and attached to the bottom of the light. I don't plan on mimicking the electronics of his design, just the housing.
    Function over form.... form will follow once I get the basics down.
    Some naming convention confusion, that's all. Typically when you have batteries only wired in series or only in parallel, they are described as 4S or 4P. But they're also described as 4s1p, to describe the number of cells in the pack as a multiplier 4s x 1p = 4 cells; 4s x 2p = 8 cells, etc).
    It's also helpful to do the mah on the value of the cells in capacity - a 8.4v 6000mah 2s2p pack would tell you it is (2) 8.4v 3000mah packs in parallel, where each of those 2 packs are 2 cells made up of 3000mah cells.
    when you get to the build - make sure to post pics, we love pics round here!
    No talent hack
    One last elementary question.... about soldering.
    A while back, I bought a Hako FX-888 soldering station for working on my automobile stuff. I really like it as it is the first "real" soldering station I have ever had. While I love it, I feel like I have to use "too much" heat while soldering and I am a bit worried about damaging the driver while soldering.
    For soldering the connections and stuff, I have a spool of 63/37 Tin/Lead .025" flux solder. It seems so simple, but is this the correct solder for working on these components? It works fine on cars, but wiring can handle more heat without being damaged.
    Thanks one more time... I think I am finally ready to order parts.
    No talent hack
    All right... here is my rough parts list. I still need to find a source for good batteries (and a charger for them; suggestions are welcome because the parts source sticky is pretty out of date for most things. I am in the US if that matters).
    Does anyone see any holes?
    First DIY light Project total = $67.79
    Mfg Model Source Price Notes
    LED Cree XM-L LEDSupply $10.05 Cool white
    Optic 1 Carclo Narrow frosted LEDSupply $1.25 Spot
    Optic 2 Carclo Ripple Medium LEDSupply $1.25 Flood
    Lens holderCarclo N/A LEDSupply $2.20 Order 10 for future
    Driver Taskled B3Flex TaskLED $35.00
    Battery 18650 4 batteries
    Misc Artic Alumina Amazon $7.99 2 part epoxy
    I have Artic Silver 5 from computer builds to use where I need.
    Reputation: Ofroad'bent's Avatar
    Quote Originally Posted by Knight511 View Post
    Might want to try these optics for the spot:
    Good XML optic
    Also may want a neutral tint rather than cool.
    Also, for a bar mount, you should look at the eliptical optic for the near field flood. It has a really wide dispersal horizontally (~40deg) and only 11-12 vertically, so it won't be throwing too much light up into the tree canopy.
    For decent quality 18650's - Tenergy protected 2600's aren't bad: 4 pack - All-Battery.com: 4pcs Tenergy Li-Ion 18650 Cylindrical 3.7V 2600mAh Button Top Rechargeable Batteries w/ PCB
    At least if a cell dies, they're US based and I've had good response out if their customer service.
    If you're looking for some of the best out there - Panasonic 3100mah or 3400mah are out there, - ~$12-18 a cell. Look for those with protection circuits added though - you don't want unprotected cells, even with the b3flex's settings. I can't recommend a retailer, as I've not bought any of these, and there are reportedly a lot of fakes on the market.
    Usually batteries with the word "fire" in the name is usually pretty far down the quality scale. Lot of overstated claims on capacity. The Panasonic3400's are the best that are available. Ultrafire's labeled at things like 4400mah, are simply lying. Usually those batteries struggle to take 2000mah on charge.
    For chargers - any of the "4-button" models out there are all basically the same - Turnigy Accucell-6 is what i just bought - Turnigy Accucel-6 50W 6A Balancer/Charger w/ accessories
    Quote Originally Posted by Ofroad'bent View Post
    Good XML optic
    'bent,
    How are you affixing those optics to the LED's on your Easy2LED housing builds? I have a couple of builds coming together using those.
    Quote Originally Posted by adrenalnjunky View Post
    'bent,
    I've only used them in Easy2LED housings so far, and the threaded lens holds them in place. I had to dremel a divot to clear the cable entry, but otherwise drop-in.
    No talent hack
    Biggles - Thanks for that input. I had seen the elliptical and pondered on it, but thought it might be too wide... knowing that it doesn't throw upward too will likely send me to it for the near flood light.
    Adrenal - Again... thanks. The batteries were really the last piece... with the time change a week away, I can't get this going too soon. I actually looked at that charger this morning. When you charge with that, do you just hook the battery box up to it to charge them all?
    You tell the charger how many cells in series your pack is, then you can set your charger for a maximum capacity.
    You'll get to full charge before it hits capacity, and the charger will end the cycle.
    Lotsa settings on these chargers to tweak for your needs.
    Sent from my cm_tenderloin using Tapatalk 2
    No talent hack
    Made my order with LEDSupply. TaskLED is not shipping until November 12, so that is a drag.
    When I search on Google for the 4s1p 18650 battery holders, I come up with a bunch of results that have PCBs on them. Do I need the PCB option since the batteries are protected?
    No talent hack
    Scratch that. Just ordered the battery cases without the PCBs from DX.
    So I am going to dual build.... using a second light for mowing my yards for my Honda HRC mower... I hate how early it gets dark now...
    I've thought about building a lightbar for my cub cadet and retiring a couple of my older lights to lawnmower duty.
    No talent hack
    That is only funny to me because before I ordered with DX, I went and measured my mower's "handle" bar and ordered 2 extra velcro type flash light mounts to build a light bar across since it doesn't have a cross bar that doesn't have the controls. I figure just as a cheap light bar, I can cut a piece of PVC (already have extra in the garage) and paint it black... it isn't load bearing except for a little light.
    I may be equally excited about building a light for my mower as my bike.... I think that may be a bit crazy.
    No talent hack
    I just got my order with TaskLED put in and confirmed. So I will have the B3Flex shortly and should be able to proceed with building the first light.
    I guess I didn't realize just how painfully long ordering from DX is. 2 weeks and the best I can tell the order is floating in the Pacific. This is my first international order, so I am just use to actually being able to track closer than this.
    DX is hit and miss on tracking. You can take your HK post tracking number, and search USPS for it. when the package hits the International Service Center, those numbers are added to the USPS system. Some times you order on Monday, and tracking shows it in USPS system 4-5 days later. then depending on USPS - they may sit on it for a while. My last DX order hit New york in 4 days, then sat there for 2 weeks.
    I also ordered a pack of tactile switches from a seller in china, it hit USPS 5 days later and then tracked through the US to a city 90 miles away on August 6th, then never moved again. No one @ USPS could help me, cause the package didn't have delivery confirmation. USPS told me I needed to initiate a claim with the seller. (Ummm...the seller got it to the USA, you guys lost it after it moved though 3 USPS distribution centers) It was a $2 purchase so I just bought another pack from a US seller this time.
    The original package showed up in my mailbox Wednesday of this week. Oh well.
    No talent hack
    Just checked USPS and it agrees.... some where in the Pacific.
    Ordered 10/31... left HK 11/9... currently waiting for a current or breeze in the Pacific.
    After this order, I will have to poke around more to see if there are US suppliers for the cheaper drivers for "fun" lights.
    illuminationsupply.com or LED Bike Light projects
    Both are in the states and keep a couple models of popular inexpensive drivers.
    No talent hack
    So much for tracking.... it all showed up at my house today. :-)
    Early Christmas!
    No talent hack
    I had some set backs during the holiday season around Thanksgiving with my cat, so I didn't get around to doing anything after I got my stuff in. I finally got a bug to get out and search for parts....
    total bust.
    The 3/4 inch copper caps I want to use are all had rounded ends and not flat like Project Copperhead used. I went to multiple stores but all were the same, so I am taking a new direction and will likely end up using a Hammond box for my dual light set up (I did get a small aluminum box that will be GREAT for my single light I want to play around with).
    I need to spend a day at my work bench in the garage and get things sorted so I know what I need to get to actually build it.... and I need to get out and buy batteries. Any reason to not buy Tenergy branded 18650 2600mah batteries? I have already sourced them locally.... I know to stay away from "fire" brands, but am curious if Tenergy are any better,
    Reputation: yetibetty's Avatar
    I have used Tenergy 2600ma 18650's and had no problems.
    Just try not to buy old stock.
    Dec 2011
    ? for you guys
    when using a 12 volt source "constraint" "has to be" say car or motorcycle battery
    and choosing to run xml's
    is the optimum... 3 XML's in series with a b3flex driver?
    ideally 2 amps are optimum for this application.
    Would 2 xml's in series be too hot and less efficient. 6.6V/12V
    Will the driver allow 4 XML's in series, due to the lack of "overhead" 13.2V/12V
    Is there a driver for 12 volts and 2XML's in Series.
    Thank you guys so much, this is really cool, wished I wasn't so ignorant.
    3 XM-L @ 2A in series is going to be about 9.6v forward (figuring ~3.2V per emitter). If you have a power source that can provide 12V, and this is the important part: can provide that voltage under load without sagging below ~11.5v - then the b3flex would work. A car or lawnmower/MC battery has plenty of current on hand,so i wouldn't expect it to sag out under load.
    running 2 XM-L wouldn't generate any more or less heat in this situation, cause the b3flex is a regulated current step-down controller (aka: buck driver), it isn't generating hardly any heat to do what it does, as long as it is provided the overhead voltage it needs to do its job. 2 XM-L would be optimal on the b3flex if you were trying to run from a smaller battery pack (lithium cells) where you were concerned with the pack sagging under load, or after a bit of runtime, and everything going direct-drive on you.
    Not enough overhead for 4 XM-L - not on a 12v source. Since you throw out 13.2V as well, I'm assuming you're building off-road lights to be run on a automobile, or ATV. This is discussed from time to time - and George @ TaskLED cautions that his drivers aren't specifically designed to deal with automotive electrical systems - mainly dealing with the big current spikes and "dirty" voltage that can be seen with automotive charging systems.
    I'm not saying that it won't work - I've got a mind to do something similar myself - but I would at least warn you that there is the possibility for failure.
    for 3 XM-L - and if I'm correct in what you're trying to do - I'd use a H6CC instead of a B3flex. It needs less overhead. 4-XM-L on a 12v source isn't going to work with a buck driver. Your Vin is too close to Vout.
    Dec 2011
    Thanks guys,
    PM's sent
    much appreciated!
    Dont forget George ( Taskled ) has got a driver specially designed to run 3 XMLs from a 12 volt car / auto environment .
    as he mentioned on the motorcycle thread .
    Regarding driver choice for automotive use. The hyperboost, even though it can handle pretty high input voltages, is still a BOOST driver. The issue with Boost drivers is that they inherently have a DC path from the input to the output. This means if you were boosting say 20V of total LED Vf from 12V, even though all appears wonderful... when a 30V or 40V or 50V transient occurs on the input, that transient will direct-drive through the DC path to the LED load....
    Without a transient suppressing circuit at the front end of a Boost driver, I would never recommend its use in an automotive environment.
    For a buck driver (3A drive) that can handle automotive voltages, I do have a solution that is NOT on my website. It is well proven for automotive use and if the driver is thermally bonded to the LED heatsink, it will also limit maximum temperature to 60C. It will automatically reduce output current as needed to prevent exceeding 60C. The thermal rollback is implemented as an analog solution, so the current reduction/dimming is barely noticeable in normal use. Obviously with any airflow the housing will cool quickly and the driver will raise output current back to nominal 3A.
    cheers,
    george.
    I got 4 from him before xmas but have not yet built the lights
    Dec 2011
    thanks troutie,
    sent him a pm as well
    Thanks for all your input to this forum.
    You guys are great!
