Results 1 to 5 of 5
    Dec 2005
    Driver for XM-L that doesn't require momentary switch?
    I'm looking at making a pair of lights for my trail / motard bike using some XM-Ls but so far it seems like the drivers that can supply up to 3A are all multi mode types that are operated by a momentary switch. All of my previous lights have been made with single mode drivers and I'd prefer to use them for this application so I can just hook the lights up to the bikes wiring and not have to press a separate switch whenever I want the lights on.
    Any suggestions?
    Dec 2005
    Looks like i might have found a solution- HipCC. It looks to be a single mode buck driver with a default drive current of 2.8A
    Anyone see a problem with that plan or got a better alternative?
    thanks
    Reputation: HEY HEY ITS HENDO's Avatar
    hmm yes there is a slight technical hitch with your selection....
    they are no longer in production lol
    try this ....
    http://www.taskled.com/h6cc.html
    ...Scun.thorpe, UK
    Dont forget the other drivers can be set up for power on mode
    so will work with an on off switch .
    As per Hendo, h6cc and adjust onboard trimpot to set desired current, ships set to a nominal 2.8A.
    cheers,
    george.
