Results 1 to 2 of 2
    Dome On Cree XRE
    Anyone removed the plastic lense dome on the emitter? Mine poped out and the light seem bright and CLEANER without it. Problem is, it turn bluish, then yellow and eventually die after abt 3 1/2 hrs on 1amp. But light was good for the first 3 hrs.
    I had one come off but it was because I overheated it. Driving at ~1350 milliamp will do that. It's still running now, albeit at ~1000ma even after melting the lense off. I would look into your heat-sinking and airflow situation. I have ~20 hours on the one that I damaged and it still runs fine. It is a Q5 bin.
