Results 1 to 11 of 11
    Do the Germans build the brightest bike lights?
    Siams new light: 20V-40V, 75A, 165000 lumen
    thread and on youtube
    is that a mercury lamp on a mountain bike?
    I WANT TO BUY YOUR MAGICSHINE LIGHTS! Working or not.
    dirtbag
    Reputation: ranier's Avatar
    Sep 2003
    Whoa, a bit overkill there...
    Amolan
    Exposure Time (1 / Shutter Speed) = 10/100 second ===> 1/10 second ===> 0.1 second
    Lens F-Number / F-Stop = 20/10 ===> /2
    Exposure Program = manual control (1)
    ISO Speed Ratings = 800
    WAYYYYYY overexposed. Probably just a MS 900 or similar.
    Quote Originally Posted by BKruahnndon
    It's a booster rocket from the shuttle, now that they are shutting down the program they are trying to get rid of surplus parts.
    whs
    whs is offline
    Quote Originally Posted by Bryank930
    Lens F-Number / F-Stop = 20/10 ===> ƒ/2
    Unless you failed to add some smileys, tehn all I can say is: Gives us all a break.
    ISO 800, F2, 0.10 s is equivalent to ISO100, F4, 3.2s, so below the mtbr forum standard, also just below the IBC forum standard. If you really think that's "just a MS 900" then you're crazy. Read the thread. Sure, it's in German but if you don't read German you can try it through google or just watch the pictures.
    for what I know,
    it's definitely over 10000 lumen,
    below 2000w,
    and under 8 lbs.
    possible to helmet mount,
    with heat shield, reaching 1600 Celsius temperature,
    incinerates stray moth, mosquitoes, and other insects in mid air,...
    sunglasses required
    maybe some day, I'll do a LED version,...
    cheers, Rob
    This is a 1'500 W over 100'000 lumens "bike light"
    Siam's thread on CPF (English)
    .. side to side with MS
    .. and green leaves catch fire if you stop for too long (watch at 1:20)
    Siam's LED light
    He did it again - this time the LED-way ...
    7 x 7 XM-L
    the irony is, he has all that light and the video was on a fire road Certainly technically impressive and an interesting insight into "what if..?". Having that soft shell 8S?P li-po pack in a backpack would thoroughly scare the $hit out of me though.
    Reputation: Goldigger's Avatar
    Is it me or does it sound like he's running along pushing a shopping trolley?
