Results 1 to 2 of 2
    New question here. diy upgrade? 4 a newbie
    1. I have a Niterider mini USB. Been using for short time but not very happy with its light. Cars can see me but on dark streets, barely illuminates the road for pot holes, etc.
    a. Can I pop in an LED with higher lumins? The battery li-on battery is 3.5 Volts. What battery would I need?
    b. Can I use either rechargeable NIMH 3 AA or 3.6 battery pack as a back up for the light as is?
    2. I have a NITERIDER CLASSIC SELECT w/ DUAL LIGHTS 10/15/25 - 6 volts.
    I notice that the NiteRider Classic 12/20/32 runs on 13.2 volts.
    a. Aside from the wattage difference, does the 13.2 volt system burn brighter/longer? If both have similar halogen bulbs, how does the Select run on only 6 volts?
    b. Can the Select be upgraded?
    c. Is there any way of squeezing out more time on one charge, e.g., using recharchaebles with higher mAh?
    Hope slight correcton to my questions above
    Is there any way of squeezing more riding time from one charge, e.g., using a rechargeable with higher mAh.
    Thanks.
