Results 1 to 7 of 7
    DIY (sort of) High Lumen self contained bar lights - NOW WITH BEAMSHOTS!
    Hi All,
    Have posted all the details of the 'build' over on the 'Lights and Night Riding' Forum
    Have a look at
    http://forums.mtbr.com/lights-night-riding/high-lumen-self-contained-bar-lights-780292.html
    Detailed write up a and lots of photos such as this one.
    Enjoy!
    Attached Thumbnails Attached Thumbnails DIY (sort of) High Lumen self contained bar lights-2012-04-08-11.44.22.jpg
    Reputation: Goldigger's Avatar
    That niteye eye30 is a bit of a beast..surprised it only puts out 2000 lumens on turbo mode..
    Any chance of a beam shot with the mtbr camera settings?
    White balance daylight
    F4
    6 seconds
    May 2005
    Nice project though I think adding at least a pound of weight on top the bars would make for some noticeable, likely negative, handling changes.
    Quote Originally Posted by Goldigger View Post
    F4
    6 seconds
    Will try
    Quote Originally Posted by Vancbiker View Post
    You'd think so, but because its mounted that close to the stem its not an issue at all.
    May 2005
    Quote Originally Posted by Fury25 View Post
    Interesting. The reason I thought that it would is my son and I have almost identical SC Blurs. Mine has a Fox Float though and his a Fox Vanilla. Same travel, just the Vanilla weighs more because it is a coil spring instead of air. His bike is noticeably "front heavy" compared to mine. Harder to lift the front when riding over logs and rocks, etc.
    Beamshots are now up - lots of them
