Results 1 to 15 of 15
    Reputation: ktronik's Avatar
    DIY Shimano STI interface for Bflex/maxflex
    DIY Shimano STI interface for Bflex/maxflex... for road / cyclocross
    DIY Shimano STI interface for Bflex/maxflex-sti1.jpg
    DIY Shimano STI interface for Bflex/maxflex-sti2.jpg
    Control your LED light from your un-used flight deck computer button...
    lever in pic shimano 105 10spd RH shift / brake lever
    it works better than I had hoped, the nice & solid 'tact' switch gives for a great snappy feel.
    I cant show this one installed on a bike, as its for a customer OS... more pics soon...
    K
    and use the other STI shifter for your motor switch! ....kidding.
    nice integration!
    Rep Power Infinity +2
    Reputation: brad72's Avatar
    You beat me to it, I just received the momentary buttons to go into my STi lever hoods to control the Bflex as I was sick of moving my hand to the center of the bar to change power levels. Just need to re-tape the bar to hide the cable and she will look sweet. Nice work
    Quote Originally Posted by brad72
    You should know better than try to beat me to it!! ;-)
    6mm stalk on the tact works great and is needed to clear the inside of the lever body
    BTW guys, modding a flightdeck switch unit is a waste of time, mod to the blank in there is the go.
    Enjoy
    ktronik
    Quote Originally Posted by BKruahnndon
    nice integration!
    Don't temp me, you know I will do it!!
    K
    nice integration!
    I have a company that sells the small motors that would fit into the seat tube. Would be a fun project
    like this brad, http://www.gruberassist.com/english/...t-description/
    Defcon Cycles - Brisbane Australia
    Here is the circuit for the E-bike's throttle input, reduced to a simple form, so my STI or another button can be used as a WOT style throttle for ebikes...
    still needs a diode across the coil to stop BEMF
    so MOM on to start, pull brake to re-set (turn off) relay...
    I have already done it & it works great...
    K
    DIY Shimano STI interface for Bflex/maxflex-stiremote.jpg
    and now with button on the 'tops' of the bar...it would sit just after the HB tape ends on the top of the bars...I would run mine under the 'tape' to hold it in place...has a plug on it for removal from light.
    K
    Jun 2010
    Quote Originally Posted by ktronik View Post
    Enjoy
    ktronik
    What do you mean by "tact". What switch type has the 6mm tact that you are speaking of?
    Is the tact the same switch with the clear plastic covering shown in the photos?
    Could you run just the (clear plastic covered switch) underneath the brake hoods or do I need to buy a flight deck switch from Shimano?
    Reputation: yetibetty's Avatar
    Tact is short for tactile. Loads on ebay for next to nothing Electronic Components PCB Microswitch Switches 20 pcs | eBay
    Jun 2010
    Thanks. Where do I find the clear plastic cover that makes the tactile switch waterproof, like the one shown in the photo above?
    Any idea what suppliers have these (with waterproof covering).
    Quote Originally Posted by ThinkBike View Post
    Looks like clear plastic heat shrink to me, with some black heat shrink on either end
    Quote Originally Posted by DIYtailight View Post
    Yep, sure is...
    Jan 2011
    Nice work ktronik - very slick integration. Shame my Sora shifters don't have the flight deck controls, otherwise I'd be sorely tempted to give this one a go.
