Results 1 to 17 of 17
    DIY LIPO Charger
    5 Cell 2 AMP 20.8V
    Build :
    Based on the Linear LTC4012
    4Layer 2oz FR4
    PIC 18F14K22
    700 Lines on C Code.
    4D Systems OLED Display
    This was a lot of work. Now I wont be at the mercy of stock chargers...
    Dwight
    PCB Layout
    That's impressive. Believe it to be a first over here on the forum.
    Nice work.
    Feb 2006
    Wow. Lots of work, certainly above my intelligence grade.
    back side view pcb
    May 2005
    Wow! Awesome bit of work there. Does this have features beyond those offered in the RC lipo chargers? Are you producing this PCB for sale possibly?
    Rep Power Infinity +2
    Reputation: brad72's Avatar
    Nice charger. Who did you get to fabricate the pcb?
    Reputation: piesoup's Avatar
    That certainly is impressive!
    Is is set to 5s batteries or will there be options / software changes available for smaller batteries?
    I like it as I use 5s batteries!
    Aug 2010
    Awesome work. Nothing beats being able to make your own boards and having something designed exactly to "your" needs/specifications
    Will
    Quote Originally Posted by bad andy View Post
    +1 on all counts
    Formatted Screen.
    The design will support 3s,4s,5s packs with varying current from 0-4amps. 95% eff ->(Synchronous Buck). Minimal heating with all components under 40C @ Worst case (45watts). To be honest its surprisingly stable and well behaved. The LTC4012 does most of the heavy lifting and the PIC monitors time,temp, voltage and current. The PIC basically tracks the process, updating the OLED, and stops the process if the time gets to long, no current, over voltage, over temp, and termination 0.1C of charge. The OLED from 4D systems is really nice and dead simple to control with serial commands. OLED's look great.
    I was using an Digital RC Charger since cheapo 5S chargers are few and far between. Plus the RC chargers did not play nicely with the batteryspace PCB protection design. I had difficultly starting the charge process after the PCB disconnected the (+) due to low pack voltage. Also, Very Few of the digital RC chargers support unbalanced charging.
    One word of warning... The Microchip MPLABS IDE XC8 (aka Microchip C Compiler) is not for the weak of heart. It might be FREE but It will make you work for it.... And please avoid the sprinf()..it a hot mess. I have to admit it has a very nice debugger
    PCB Layout Software and Boards are from PCB Manufacturer in Aurora Colorado Manufacturing Annular Ring, Printed Circuit Board Fabrication, Printed Circuit Boards, PCB Prototype Circuit Board's Its FREE...Tinny Tiny learning curve but once past it , I have really enjoyed designing PCB.
    Dwight
    Does it do balancing as well?
    Nice work. That's a new PCB fab house that I haven't heard of, will have to file that away for future reference. I've always used PCB Software | PCB Design Software | Sunstone PCB123 and don't really have any complaints, but I'll have to compare prices next time I do a board.
    Quote Originally Posted by Happy Rabbit View Post
    That's good to know about the microchip free 'C' compiler. I've always used the CCS C compiler for PIC chips, and it's quite good, but it's not free. I had thought about switching to the Microchip compiler but think I'll stay put.
    I'm also using AVR processor more and more now. The free tools are good and there seems to be more freely available software libraries and other goodies available.
    Reputation: phburns's Avatar
    Very nice work!
    The housing 120mm x 70mm x 35mm
    Finally finished the charger. Works nice. the OLED screen was a train wreck. 4d Systems, The Manufacture, changed the firmware so I had to rewrite the software and the PCB. Using the enclosure as a heat sink turned out well...fan-less. Only took 10 months to complete.. Time to focus on the bike lite..
    Dwight
    RAKC
    Reputation: tigris99's Avatar
    Re: DIY LIPO Charger
    Very nice. Beyond my skill/patience lvl but luckily I kept my good charger from when i was big into rc.
    Sent from my HTC Sensation Z710e using Tapatalk 2
