Results 1 to 2 of 2
    Cygolite Z Force HiD Problem
    Can anyone out there help me, I have a cygolite 6 V NiMH bottle battery (Nitro 100) that I want to re-pack to make it a 12V NiMH to run a Z force HiD. Is this possible? Has anyone done this before?
    Cheers.
    Reputation: California L33's Avatar
    Quote Originally Posted by twiddlesticks
    Cheers.
    I've never done it, but it should be possible if there's room inside. You'll need some solder tab 'C' size batteries- wired in series, not parallel. You should probably replace them all, not just add another 5. (Check Froogle, there are many suppliers), and possibly a new circuit breaker (don't make a battery pack without one, those batteries may be small but they pack a serious charge, and the last thing you need is a flaming battery pack between your legs if you get a short- because "Chestnuts roasting on an open fire," is only a comforting thought when they aren't your chestnuts). You'll also need a 12V charger.
    To the troll mobile, away...
