Results 1 to 25 of 25
    Cygolite Trion 600 Led
    Howdy Boys and Girls,
    Long time, first time etc.
    Just received my Cygolite Trion 600 Led combined light & battery unit.
    Contents:
    1 x combined light & battery unit
    1 x charger
    1 x handle bar mount with diameter inserts for different size bars (25.4mm & 31.8mm)
    1 x instruction/trouble shooting manual
    1 x registration card
    1 x carry pouch
    Performance
    • Refer to attached photo - no chance to ride with it yet. (distance to rear fence = 30m/100 feet).
    • Narrow beam, good depth.
    • white/blue light - rated @ 600 lumen
    • Compact unit
    • Charge time, burn time etc - refer to box photos
    NOTE: no helmet mount available
    Enjoy!!! - feedback welcome
    PS - Time permitting I will make an equivalent post on my Lupine Betty 14
    Put some lock-tite on the bottom screw. It comes loose at the worst possible times.
    Feb 2006
    Can I say LOL?
    It seems to be using exactly the same optics, maybe even the same LEDs as the Dinotte 600L.. for approximately the same price - smaller battery (and only one) but at least built-in the lighthead. No wonder that there is no helmet mount - I wouldn't want to put 230+ gramms on my head...
    I'd say it belongs to the $250 category... yes, the Dinotte 600L has become overpriced too...
    btw. does anyone know what optics module is that?
    Thanks for the post Fury25! I was curious about this model.
    odtexas wrote: ..Put some lock-tite on the bottom screw. It comes loose at the worst possible times.
    ...interesting...when I saw what the handlebar bracket looked like I was wondering just how well that was going to work considering what the ( all-in-one ) light/battery system must weigh. It probably would have been better if they had used an adjusting clamp that locks in ( like the Dinotte ). Still, this looks to be an interesting offering from Cygolite. The beam pattern looks very much like the Dinotte 600L. If you're the kind of person that hates having to mount a battery this could be right up your alley. Even better, it mentions the option of using an external battery so I suppose there must be a plug outlet on it somewhere which would be a nice touch. Performance is listing these on sale @ $369.
    Like radirpok wrote, this is very much in the same price range as the Dinotte 600L. Personally, I'd still rather have my 600L due to the fact that the 600L has two batteries. Add to that the fact that the 600L can swivel back and forth and tilt up and down without moving the quick release mount one iota. You just can't find a better mounting system than what the Dinotte 600L uses. Still, the Cygolite Trion 600 is a nice offering and looks to be a worthy option for the MTB'er looking for a decent bar mounted light system.
    Reputation: yetibetty's Avatar
    Fury, nice first post, thanks
    Looks like Exposure lights have some competition.
    Spanish biker
    Reputation: msxtr's Avatar
    Very nice, bright beamshot!!!
    Have 1 thing that I don't understand of cygolite company, why they insist to do the housings of your lights with "plastic"?
    Greetings - Saludos
    msxtr
    Warning!!! my english is very very bad, sorry.
    Easy DIY led light1
    Easy DIY led light2
    The Beast!!!
    Quote Originally Posted by odtexas
    Thanks for the advice.
    Now firmly secured with Loctite (red)
    Quote Originally Posted by msxtr
    Greetings - Saludos
    msxtr
    From what I can tell, the housing is metal - doesnt sound (when 'tapped') or feel (heavy) like plastic.
    maybe someone else can confirm definitvely
    Front half of light is metal with a heatsink. 4 screws out and the silver metal head pulls away from the rear black plastic battery/switch. You have about 1.5 inches of wire holding the 2 parts together.
    Flip to the back side of the silver metal head unit. 4 more screws and the whole light assembly comes apart.
    Battery section is seamless sides and back. Think of it as a small dixie cup. Whole assembly (battery/switch/ports) slide in and glued in place.
    It can surely be opened, and cells are probably available from batteryspace. But it is stamped with a nice big warning to replace with cygolite lithium only.
    Light does have option for piggyback battery. This would probably work if internal battery fails.
    I have a strong dislike for external cables. Been running Planet Bike Alias HID's. Thought this would be a good option for LED.
    Glueing one of scars batteries to a handle bar mount and velcroing the Amoeba to the battery would work nearly as well. Cost a little less too.
    Oct 2007
    Quote Originally Posted by Cat-man-do
    ... Personally, I'd still rather have my 600L due to the fact that the 600L has two batteries. Add to that the fact that the 600L can swivel back and forth and tilt up and down without moving the quick release mount one iota. You just can't find a better mounting system than what the Dinotte 600L uses. Still, the Cygolite Trion 600 is a nice offering and looks to be a worthy option for the MTB'er looking for a decent bar mounted light system.
    Not to mention that the 600L has a 3.5 hr burn time per battery. Dinotte is definitely a better deal unless you are looking for a self-contained unit. The self-contained aspect is pretty appealing - not so much for my night bike, but for my errand bike. Hmm. Must-not-spend-money . . . must-not. Aggh.
    Does it look like the battery is user replaceable or is this another one of those back to the factory deals?
    so fury25 how is the light working for you?
    Quote Originally Posted by uchinanchu
    Light works very well - even when compared to my Lupine Betty 14
    The Lupine is obviously brighter and with more penetration and a wider spread but the Trion 600 performs excellently even in this company.
    I will try and post comparative real ride images when time allows.
    Hope this helps
    Oct 2007
    Haven't found any reviews on this light other than this one thread. Has anyone seen any comparisons between this light and any of the other regulars?
    Quote Originally Posted by Cino
    Hi Cino.
    I am also the proud owner of a Lupine Betty 14 Light Unit.
    I wil try and do a comparable light shot and post tonight.
    Apolgies for not having done so sooner.
    Nov 2008
    I've just also got Trion600.
    Although I do not have other regular lights shown in this forum, I have some LED lights and an old small halogen light.
    Distance to wall is about 3m. ISO50, F2.6, 1/8sec.
    1.Fenix L2D Premium Lebel100 turbo mode(claimed 175lm).
    2.UltraFire C2 Q5 modified for using external battery (Perhaps over 200lm)
    3.B&M IXON IQ
    4.Trion600 High
    5.Cateye HL-500II
    Hope
    Hi Chino.
    'Real Life' photos as promised
    Sorry about the quality of the photos - best I could arrange at short notice with compact digital camera. Hope this helps
    Distances calulated as per Google Earth
    Camera settings
    Trion 600 @ maximum power (600 Lumen)
    Lupine Betty 14 @ Maximum power (1500 Lumen)
    Oct 2007
    Thanks Fury,
    Maybe the camera registers light differently from the human eye. Under identical conditions, the shot of the Betty doesn't really look that much better than the trion, yet I am sure that in person, there is no comparison. True? What I see is that the Betty is only slightly brighter but throws light everywhere - that is, it has a slightly more intense beam but much wider. Is that true or is the Betty a lot more intense as well?
    Edit: OK, after adjusting my display I can see that the Betty IS a lot more intense as well. That has got to be a spoiler, after getting used to the Betty, how can you enjoy using the Trion?
    Thanks Fury,
    Hi Cino,
    You are correct. The photo does not really show the differential between the lights. The Betty blitzes the Cygolite, however, the Cygolite is still a good light.
    I also took the same photo with both llights on, and interestingly enough the Betty washed out any noticeable contribution the Trion was making.
    To answer you question:
    Betty = MTB
    Trion = road bike
    As long as I dont have the side by side, the Trion suffices for its intended purpose.
    Oct 2007
    Thanks, Fury. I went ahead and ordered one from Performance while they were on sale.
    Hi Cino.
    Good Luck. For what it is it does its job well. Dont forget that you can also get and external battery for longer burn times (approx 6 hours all up I think).
    Post some photos
    Oct 2007
    Well, I have the Trion, but have had limited opportunity to check it out. Still, I am favorably impressed. Played w/ it a bit next to the 600L and the beams are very comparable both in spread and intensity. Seems to be well made too. This could be a very good light for situations where you may need to lock the bike up and take the light w/ you, and it is still plenty bright enough for serious night riding.
    Any updates? How's the bracket holding up? Does this thing look durable?
    I am interested in this light, because I don't want to deal with having a battery pack on my full suspension.
    Throw is not all that good. It is holding up well. Once you put loctite on screw holding clamp to light body everything stays put.
    I would recommend Scar's Amoeba over it. I like the color and throw of his spot version Amoeba alot better than the Trion 600. It can be mounted on the handle bars or helmet. The Amoeba is small enough that velcro holds everything on your helmet or bar mount. That is light head and battery, so basically no cables to run. He wil be back in town and start building again. Its worth the short wait. No intermal proprietary batteries to go bad as with the Trion 600.
    Vintage Racer
    Just picked one up on eBay for my road bike, $280 after cash back from Bing which seemed like a pretty good price compared to Performance at $349 + tax + shipping. Will post review when I receive it but I'm sure it's going to be good as I've been using a Planet Bike 1/2W unit so far and got sick of hitting the same pothole every night on my way home :-(.
    Strop.
    Vintage 83 Road Bike, Full Custom Columbus SL Frame.
Hot Deals
Contests
Latest Mountain Bike Articles
