Results 1 to 9 of 9
    Cutter-4N + Cutter-XPGMR11Q
    Guys, I have seen that someone used this combo with a very good result. But XRE optics sits higher than XPE:
    Please comment on this.
    Reputation: Goldigger's Avatar
    Cut the legs down, so the optic sits on the leds
    Quote Originally Posted by Goldigger
    It would be difficult to position the optics right if I did it. I have a better idea to cut cavities for the legs in the plate but I would like do know what people already did with this.
    Reputation: ortelius's Avatar
    Maybe you could also enlarge the positioning holes in MCPCB a bit, so that shortened optics legs would fit?
    What Ortelios said drill larger holes .and shorten the legs .
    be interested in your findings I tried a triple XRE cute optic with 3 XMLs and it was not as good as the triple XPG Cute
    Quote Originally Posted by troutie-mtb
    Probably for the same reason: XRE optics sits higher than XP.
    Do It Yourself
    Reputation: Homebrew's Avatar
    The Cute3 I'm using on my XPG triple is actually the XRE version and has a similar gap to your picture. I was using XRE before upgrading to XPG. It may be slightly suboptimal but works fine as is.
    Long Live Long Rides
    The tests I did on 35mm quad vs triples using a light meter showed that you don't really get much benefit to the quad over the triple. The smaller optics in the quad and the lack of a true 35mm XPG optic means you lose efficiency. So you end up using more power for very minor improvements in brightness. You can look back at old threads I started if you want to see details.
    I also did some tests of the GT4 optic which is pretty much a flood. And if you want a flood, it's actually pretty impressive on the quad 35mm XPG board. I think it makes a very nice bar light if you mostly ride tight twisty trails.
    I find only with triple
    Just now measured 4XP-G R5/Cute 4SS@0,5A dist. 1,7m - 1700 lux.
