Just about finished my custom light build, so thought some of you may be interested to see it.
I'll start off with saying that this is my first build and I'm not an engineer ;-)
Design around a SCC P7 with 52mm DX P7 Reflector, access if via a removal rear section.
P7 will be mounted on to a heatsink in the middle. Driver boards on the reverse.
60mm aluminium with 5mm walls.
End cap welded in place. (this will be machined smooth)
Front and back sections test fit and testing mount.
P7 Mounted to the heatsink / bulkhead.
Heatsink / bulkhead mounted in the main body and driver installed for testing. (Boards will be secured to the reverse of the heatsink).
Main body with heatsink / bulkhead removed - painted.
End cap - painted but not cut / polished. The hole is one of two which keep both parts together, it is also used to mount the mount bracket.
Assembled
Mounted
Not got any 'action shots' yet, currently waiting on some new cells.
Assembled
Mounted
