Current Drive Selection
With this much choice, what are the logical choices (Heat vs Output)
• 0 click (dim) → 350 mA select (shipping default)
• 1 click (brighter) → 500 mA select
• 2 click (brighter) → 700 mA select
• 3 click (brighter) →1000 mA select
• 4 click (brighter) →1200 mA select
• 5 click (brightest) →1300 mA select
Or does everyone just leave it set to the default..?
it all depends on the houseing and the which led your using
for me, (I think it is) 3x XPE R3 and 4x XPG R5 its in a 7UP
i would set it at 700ma for a balance of run time and output but have a look here for some more info CLICK ME
Ok, thanks for that... runtime is fine as I have used a 3x 4cell arrange which should be about 7.8Ah and was experiementing with setups but will set it at either 700ma or 1000ma to see if there is any difeerence if none that is worth it, then I will just leave it at 700ma as you suggest.. cheers..
- You may not post replies
- You may not edit your posts
Forum Rules
