Cree XRE Q5 Led Direct to Battery??
I have a left over XRE from a previous DIY light,and I am going to be using it for a trail running head light,
I have 3x AAA rechargeable NiMh battery to power it.
Would it be ok to connect the LED direct to the batterys (I will be using a simple on off switch in series) or will I need a resister/driver?
Since 3 x AA's give 4.5 v a 3.9ohm resistor to give an output of 350mA or just use 2 x AA and no resistor. To get an output of 500mA use a 2.7ohm resistor with the 2 xAA's.
I have a flashlight that uses 3 alkaline AAAs and drives a Luxeon 3 directly. It works even though the voltage is higher than the Vf of the LED because the AAAs can't deliver more current than the LED can tolerate. I have never tried it with NIMHs so your result may differ.
I was thinking of using the 3 x AAA to keep the weight and size down since NiMH cells have a run voltage of 1.2V(as far as I know),and I'm sure the XRE was rated at 3.7V
The batterys I'm using are 850mAh,and again not sure,but I think the XRE was rated at 1 Amp
I've done it from a single 18650...yes it smoked the XR-E
AAA`s are not very powerful, you will be ok direct driving,
of course the XR-E will need to be on a heatsink of some sort!
No wonder! I'm squeezing 3.5A out of 3000mAh freshly charged ultrafires
- You may not post replies
- You may not edit your posts
Forum Rules
