Results 1 to 7 of 7
    Colored LED for night recognition.
    I was thinking about rigging up some colored LEDs, something like would be in a keychain, or behind a faceplate on a piece of audio equipment, and putting them on the top of my fork legs so that other friends can tell it is me when ridding dark trails. I am still new to the DIY lighting thing, so I dont really know what it would take to do this.
    Can it be done with just two LEDs, a switch, some wire and a battery, or would you need a driver for it too? Also, would a watch battery work for something like this?
    Reputation: bumphumper's Avatar
    Jan 2009
    Hi e39, good idea. Ive seen a few folks use something like this:
    http://www.blinkers.co.uk/blinkers-products.asp
    Highly visible even at long distance!
    If you go the diy route, you could use some 3mm leds and depending on the supply voltage you may only need a series reistor, no driver needed.
    If you google "led series resistor calculator" you should come up trumps
    hope this helps
    Thanks bumphumper, there was a lot of info from in that search. I guess once I pick an LED, then I can use the calculator.
    Is there a certain name for this type of LED? I am not having any luck finding them on DX.
    Also, I wonder if blue LEDs are illegal in the US?
    Lets RIDE!
    Reputation: Jim Z in VT's Avatar
    I would guess you want the 3mm or 5mm LEDs. I haven't come across them at DX, but RadioShack has a pile of them. The "MCD" number is a measure of brightness.
    I don't think a single tiny blue LED is going to bother anyone, but if you'll be riding roads with it, a call to the local police station would answer that question. I have heard of people being stopped for having blue accent lights on their cars.
    JZ
    It's not about speed, it's about lack of control.
    Carbon8er
    Reputation: El34's Avatar
    Jan 2009
    Here's what you need baby!!!!
    http://www.dealextreme.com/details.dx/sku.23490
    You would be the envy of all you meet
    Well, I went to RadioShack, and bought some green LEDs. I wanted to try one, so I took the bulb out of my Mini Maglight, and inserted an LED, and the stupid things are yellow. They had three different types of green LEDs, so I guess I will try some different ones.
    Reputation: piesoup's Avatar
    Quote Originally Posted by e39-540i
    If you put too much juice through a green led they do go yellow in colour. Do you have a multimeter? Set it to continuity, then touch the leads to the legs of the led. It should light up, albeit a bit dimmer.
