Results 1 to 12 of 12
    t0m
    t0m is offline
    Jun 2013
    Cheap DIY 18650 Lithium Battery Charger
    Hi, I'm new here. I made a 18650 Lithium battery holder for a DIY charger for my bike lights and want to share.
    Link: Magic Smoke: 1 Lithium Ion Battery Charger
    May 2005
    Excellent DIY project.
    neat, I've been thinking about doing that for a while as I've used those little charger boards a bunch. You could always use wires with neodymium magnets glued/ soldered to the ends too.
    t0m
    t0m is offline
    Jun 2013
    Interesting idea with the magnets, I'll have to give it a try although my understanding is that they are nickel plated which is tricky to solder.
    Reputation: Ofroad'bent's Avatar
    I just ordered some of those little boards, to make up some emerg chargers for work with connectors for my bike light batteries, when winter commuting time comes around.
    Quote Originally Posted by t0m View Post
    yeah, I'm not really sure about that either. I also read somewhere that heat destroys the magnetism, although I'm not sure if that applies to rare earth magnets or just the normal ones. Still, might be worth a try if you have any to hand.
    I love those charger boards, they really are a lot of fun to use. I have them in 3 or 4 lights and they give a lot of "wow" factor for only costing $2-3
    Dec 2013
    Cool, this DIY idea is great. But is there any good bike charger's brand? Got a RavPower 14000mAh but need another one now.
    because GIANT
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    yeah soldering magnets is a fine line between...will the solder stick
    and survive the pulling ? or will it be rock solid but the heat needed to bond it destroyed the magnet
    will take some experimenting...it is better to use small alligator clips
    holding a magnetic ball. guaranteed to work* and no loss of magnetism from soldering
    *some batts have non-magnetic caps
    FYI---you have a fake cell shown in the pic, no such thing as a 3800mah 18650 as of todays date. might consider sourcing different cells, as fakes might suddenly vent. I have 6 true ultrafire blue wrapped and they print them differently
    statement from ultrafire: Beware of fake Ultrafire 18650 batteries
    We are the manufacturer and owner of Ultrafire products ,and here declare that we had not manufactured over 3000mAh above for #18650 rechargeable battery, we do not take any responsibility in respect of any fake products.
    For your safety, please purchase Ultrafire products from our official dealers and distributors. Please support original products and welcome to email us if you have any questions about our products.
    Many thanks!
    t0m
    t0m is offline
    Jun 2013
    Solderable magnets
    Quote Originally Posted by mattthemuppet View Post
    I found a source for solderable magnetic connectors in the UK.
    Magnetic Electrical Connectors 5 Pairs | Rapid Online
    I made up a bunch of these chargers with 5.5mm connectors for very little $.
    I wonder if it would make sense to incorporate these little mini-usb chargers right into battery packs? Might be tricky to waterproof, but perhaps an inner tube could stretch over the opening. Wouldn't be too hard to make a small silicone plug for the connector.
    t0m
    t0m is offline
    Jun 2013
    Quote Originally Posted by Ofroad'bent View Post
    They are cheap enough. I'd certainly like to see it if anyone has a go.
    By the way you can also hack these boards to charge little Lipo cells more slowly. Bit off topic but I can post details if there is any interest.
    t0m
    t0m is offline
    Jun 2013
    Such as LiR2032 coin cells:
    Blog post: Magic Smoke: $1 Lithium Coin Cell Charger
  1. home brewed battery back - 18650? 26650?
    By sixteenornumber in forum Lights and Night Riding
    Last Post: 02-12-2013, 05:54 AM
  2. Replies: 2
    Last Post: 02-07-2013, 07:56 AM
  3. Battery advice, (probably a repeat) best 18650 li-ion?
    By rideit in forum Lights DIY - Do It Yourself
    Last Post: 10-22-2012, 10:54 AM
  4. Lithium Ion Battery Question (shelf life)
    By veteran_youth in forum Lights and Night Riding
    Last Post: 11-17-2011, 04:00 AM
  5. Good 18650 Charger
    By Dictatorsaurus in forum Lights and Night Riding
    Last Post: 03-11-2011, 11:38 AM
