Results 1 to 2 of 2
    Uncle
    Reputation: Entrenador's Avatar
    Charge time -- how fast?
    My hooptie light system is an old 6v Cygo Lite twin bulb. Since the original battery was leaking, I bought a bigger sealed battery which should yield a longer lasting beam. The new battery is a 6v, 4.5 amp/hour battery -- pretty beefy. The original charger output is 500mah, which according to online calculators, yields ~ 11 hour charge time for this battery.
    Question: How "big" a charger can I use with this battery? Is 1000mah too much?
    Thanks.
    Reputation: heatstroke's Avatar
    Jul 2003
    you're stuck with that time for sealed leadacid :
    http://www.batteryuniversity.com/partone-13.htm
