    Reputation: velomatt's Avatar
    Cateye Tripleshot mod, bFlex and Batteries ...
    I have a CE Tripleshot and want more battery time.
    I planned on buying a Batterspace Li-Ion 14.8V 7.8 Ah pack:
    http://www.batteryspace.com/index.as...OD&ProdID=2922
    I plan on placing it into a waterbottle.
    I had planned on using a TaskLED bFlex to regulate it. (the features are great !)
    Will this work ?
    Any other suggestions ?
    What about upgrading the LED's in the future ?
    thanks in advance,
    Matt
    Spanish biker
    Reputation: msxtr's Avatar
    Hi, why you want use the Taskled Bflex with the cateye light, this light already have regulation of light intensity, this don't work well??
    Greetings - Saludos
    msxtr
    Warning!!! my english is very very bad, sorry.
    Easy DIY led light1
    Easy DIY led light2
    The Beast!!!
    The regulator for the cat eye is in the battery.
    So, if I use a new battery, I will have to aqdd a regulator.
    Not to mention the neat features that the bFlex and nFlex have.
    George from Task LED emailed me and said that my idea should work.
    Once I upgrade the battery, I plan on upgrading the LED's.
    Spanish biker
    Quote Originally Posted by velomatt
    Ahhhhhhhhhh!!!!!!!!!
    Yes then are a good idea, I don't think that you have some problem with the new battery and the Bflex. If you looking for in the forum Stuar_B upgraded your cateye double and triple shot, you can ask to he if you have some.
    Greetings - Saludos
    Easy DIY led light1
    Easy DIY led light2
    The Beast!!!
