Results 1 to 3 of 3
    Cateye Tomo cc-st200 problem
    currently have a problem with my Cateye Tomo cc-st200 i put a new battery in it and nothing lights up ?? should anytihng display upon putting a new battery in or do i need to press the buttons in a certain order??
    Same issue, with Cateye Tomo cc-st200
    I was able to find the manual online in PDF form. I tried the all clear (Press all three buttons) and it was able to come back to life.
    Good luck
    Gryghin
    Listen! solution
    hi, i had the same problem, and i found the solution when i bought a new cyclocomputer...
    well, before putting new battery, i tried to remove oxydation from metal contacts with a little flat screwdriver and then the display came to new life!
    cheers and have you a nice ride!
