Results 1 to 9 of 9
    Cateye Enduro 8 mount issue
    I accidentally adjusted it to small and now I cant mount it to the handlebars. Is there a way to make the "zip tie" function bigger again and if so how?
    I re-use my zipties all the time.
    If you have a small screwdriver -like out of a watchmakers set -you can slide it between the locking tab and the serrated suface.Keep pressure on the driver and slide the serrated bit out.
    You have to pull the ziptie a little tighter so you can slip the screwdriver in easier.
    Cheers
    Dom
    If they haven't changed the design of the Enduro (mine is about 4 years old), there is a little tab you push that allows you to make it bigger again.
    Bebe's Dad
    Reputation: spearchucker's Avatar
    enduro
    sorry to tag along onto this post...I'll start another if necessary.
    I'm looking to purchase this computer. Anyone care to share their opion?
    THANKS!
    It's a simple, yet very durable computer. It has all of the basic functions and is easy to read. Very easy to install. It installs on your handlebars. They also have a stem mount that is sold separately. I would recommend it. I may go with the Garmin 305 this year for the added functionality.
    If the mount is the same as mine, you need to use your fingernail or a flathead screwdriver to lift up on the little tab that locks the adjustment while pulling out on the adjustable strap.
    Reputation: Batas's Avatar
    Quote Originally Posted by Colorado S14
    How long are your fingernails?
    livin' the dream......
    Reputation: tjkm's Avatar
    I used a toothpic on a ziptie and was able to loosen it up for reuse. Enduro 8 is good, I have had one for about 5 years w/ no issues. Good luck.
    Need to correct my last post. I've had the Enduro 2 for a few years on my old bike, just put the 8 on my new bike last week.
