    what nice teeth you have
    Reputation: nadinno78's Avatar
    Mar 2006
    cateye charger question
    So I messed up and forget to take my cateye battery off the charger before I went to bad last night. I am a little confused as to how smart the smart charger really is that came with the HL-EL700RC Triple shot, and HLEL710RC double shot lights. When the green light comes on does the charger stop charging the battery or is it just an indicating light to tell you when to take the battery off the charger. How bad did I screw up.
    SingleTrackSal
    Guest
    I think you're ok...
    I used to have a DoubleShot and I believe once a full charge is reached the charger goes into something like a trickle mode. You should be ok, but, if all else fails, read the instructions eh?
    Gone riding
    You’ll be fine.
    I’m not sure what the charger actually does once the Green light turns on to indicate that the charging has completed, but I assume the charger is a “smart enough” charger to deal with it properly.
    Dave.
    I ride a Swarf
    Reputation: Stuart B's Avatar
    Mar 2005
    yeah its fine with this charger.
    Stu
    What exactly is a rigid hard tail?
