Been messing around with different lenses on a new dual XML helmet light and noticed one LED was dimmer and more yellow than the other. Took the lens off and the LED dome came off too.
Is there any way of reattaching it and, if I do, will it work properly again or is the LED now buggered?
Got an nasty feeling the other one is loose too. Turning into an expensive experiment.
