Results 1 to 34 of 34
    Buy a MICRO LATHE ?
    Im a guy who like to learn new things and i enjoy building stuff for myself. Including bike lights. Often however i get a bit limited by the tools i have and that i have to adjust to the finnished parts i can get hold on. Many times i have thought about maybee getting some more serious tools for machining metal or plastic so that i can make parts myself . The tool that i have thought about is a lathe but my budget is limited and i dont want it to be a big thing that gets in my way as soon as im not using it so it would have to be a small and quite cheap machine
    would a taig micro lathe be a good buy?
    Other alternatives?
    What other stuff do i need to getting started?
    yes it would.
    thwang
    Reputation: yetibetty's Avatar
    I use a Taig micro lathe and it works great for me and as long as you keep projects small then it's a good answer If you have no space. The only thing is the lack of thread cutting... you have to use taps and dies. Lots of imfo here: http://www.cartertools.com/index.html
    I used it in this thread: Meet Nosey....
    This is a pic of mine making a 7up housing.
    EDIT: If you go with Taig then get the 1/4 HP (500 watt) motor for light building as the 1/8HP motor is better suited to watch making and the four jaw chuck (the only chuck I have) will be of use for non round jobs.
    Attached Thumbnails Attached Thumbnails Buy a MICRO LATHE ?-boring-584x440-.jpg
    Rep Power Infinity +2
    Reputation: brad72's Avatar
    A little lathe would be good. I have no experience with the micro lathes so cannot comment on it's capabilities but I'm sure others on the forum would. If you do get a lathe a 4 and 3 jaw chuck is needed
    As for other stuff to go with it you will need some tool steel and a bench grinder to sharpen them to the correct shape. To go with the steel you will need a parting blade and holder, boring bar and a regular tool holder for general turning.
    A set of vernier calipers and some telescoping gauges for measuring the inside diameters.
    A vertical mill slide to go on the lathe cross feed would be good. That way you can hold your workpiece in it and put a slot drill in the lathe chuck turning your lathe into a mill.
    A dial gauge and holder for centering your work
    A bottle of cutting fluid .
    Hope this helps.
    Killer b.
    Reputation: The Understater's Avatar
    Sherline.
    The Taig is ok.
    I prefer the Sherline. A bit more expensive, but far more polished as a machine. I have owned both, and I consider the Sherline to be much more capable. Sherline make just about every attachment you could think of, so if you can think of it, you can probably make it on the Sherline. I also have a Taig vertical mill which is pretty good, but I'd prefer a metric machine and Taig only do imperial.
    Either way you'll soon find buying the lathe is only the first step. You'll soon find yourself spending hours online looking at attachments and stuff to buy.
    Ebay is a good source for Sherline stuff.... and Taig too.
    Good luck.
    b.
    Posting on the basis that ignorance shared is ignorance doubled.
    A waste of time it is is
    Reputation: emu26's Avatar
    here's a good example, I've taken a screen shot as its not ofeten you see things cheaper with the aussie battler than the US$.
    Been like it for a little while now on and off but always puts a smile on my face when see it in writing.
    ebay item here
    What kind of housing are you making? What made you decide on a lathe over a mill? Both are very capable at cutting metal depending on the shape.
    Reputation: piesoup's Avatar
    Just to add my 2p, if I could choose again I'd get a mill first. A milling machine and a rotary table anything is possible. You can even do 'lathe' style cuts. I have a vertical slide and a dividing head for my lathe but it's not the easiest to use. It's not very easy to see what's going on because you're looking side on, where as on a mill, you can look down into where you're cutting.
    Happy shopping!
    Totally agree with piesoup on the vertical slide. It does drive me crazy each time I have to convert the lathe to a mill and then convert it back to a lathe again just to do one little job.
    Milling from a side on view is not too cool as you can only see one side of your work. I have actually had to use a mirror once to see the other side.
    In the end I think trying to do milling on a lathe is a pain but trying to do lathe things on a mill will be a pain too.
    In the end you will want a mill and a lathe.
    Reputation: Goldigger's Avatar
    With regards to the mill and rotary table, its a royal pain in the ass having to take the vice of my table, center the rotary table.
    Then remove the rotary table and then indicate the vice for use..
    If you have the space get a mill with a big enough X/Y table so you can mount both and leave them on the table. You'll still have to center the rotay table but without removing the vice.
    I could probably just squeeze mine on both side by side, but cant be bothered to make more clamps at the moment.
    May 2005
    Quote Originally Posted by Goldigger
    IMO you are better off if you do that. I've seen too many small mills that have the wear on the guideways and feedscrew heaviest in the center of the travel. That happens because most people have a tendency to mount their vice or other workholding device in the center of the table. Even out the wear by working over all the table travel.
    Goldigger, love the custom enclosure
    Quote Originally Posted by yetibetty
    Thanks...its a work of art isnt it?
    Quote Originally Posted by Vancbiker
    Good point that Vancbiker will have to move my vice to the other end of the table and then fit the rotary to it too
    Yep your right, I had this discussion when i bought the mill..But I'd have to add my vice gets used 95% of the time, so that side of the table will get worn more anyway, it makes sense to periodically swap them around.
    I just need to get of my ass and get some of these for my vice, but cant find them in the uk.
    I got p@ssed of with having to make stuff just to use something..
    Or make these.. http://littlemachineshop.com/Project...ViseClamps.pdf
    Best to buy a toolmakers vise that has grooves on the sides as well as slots so you don't have to buy those kind of clamps. Something like these:
    http://www.shars.com/product_categor...olmakers_Vises
    Feb 2010
    1+ on the grooves.
    Can't get them in the UK.
    The clamps arnt difficult to make.
    That was mainly for people who don't own one and may buy one in the future.
    If i were to turn my mill into CNC, would that do away with the need for the rotary table?
    I'm assuming the software can cut a circle just using x and y co-ordinates.
    also conversion to cnc, would that illiminate the backlash in the x and y??
    Is there any free software that can be used to create the cnc program?
    I have just read a forum on the very subject.
    Apparently the cost of cnc isn't too bad when you consider that you don't have to buy scales (that info will be on the monitor)or a rotary table but it helps if you had a lead screw operated head travel like the taig mill..... and yes it will do circles or heart shapes if you wanted and will also compensate for backlash(you just tell the program how much backlash you have).
    No good for me though as I'm crap with computers, I can just about draw in paint.
    I can only find one company that do a kit for my mill, but now prices published.
    I have what i think is quiet a lot of backlash, nearly half a turn of the hand wheel, can i illiminate some of this?
    Not going to be easy to elimimate backlash as your mill doesn't have anti backlash nuts that can be adjusted ( split nuts ).
    For a conversion on a mill that needs ballscrews you're looking at:
    ballscrews + nuts + hardware for installation
    nema motors + mounts + couplings + collars
    control board(probably g540) + power supply + enclosure + cables + relays
    cnc software + cam software + cad software
    Of this list, some of the things you can make yourself. Some of the software you can find free or use combo programs that do a little bit of cad with cam. Best combo I've found so far for the price is around $315 for mach3 + cambam.
    It may be easier and more cost effective to buy a small machine that has been converted to cnc. The seig x1/x2/x3 are probably the easiest to find cnc kits for if you're looking for smaller desktop machines and want to DIY. The Taig mill is rather cost effective as you can find used setups for under $2000 that include a lot of stuff.
    Best place on the web for cnc related stuff:
    http://www.cnczone.com
    When I converted my lathe and mill to CNC, I used EMC2 as the control software. I looked at mach3, but it didn't really seem to be full featured. EMC will compensate for the physical backlash in the machine via software, but you will get better results if you minimize the physical backlash. I installed anti-backlash nuts to let me adjust the bulk of the backlash out. EMC2 is free.
    http://linuxcnc.org/
    I did the conversion 4 years ago. At the time, I thought I would just use the CNC when I needed to turn out lots of the same part. But I use it for just about all my machining now. I thought the overhead of creating the CNC programs would be too much for single parts, but it goes fairly quickly once you get the hang of the overall process. There are also so many things you can do that are really difficult via manual machining.
    I started with manual Sherline machines that I ordered with the option for CNC conversion. That means they had servo motor mounts on all the lead screws. I used the machines manually for 3 years before I did the CNC conversion. Now that I look back, doing a good bit of manual machine work is pretty important before converting to CNC. It would be really hard to create good CNC programs without having a good grasp of how to machine manually.
    I will say the overall CNC conversion was no small undertaking. It took me over a year of on and off work. First step was to install servo motors on the mill and lathe. You also have to install a shaft encoder on the lathe if you want to be able to do threading on the lathe. Then I build my own motor controllers and interfaced them to the computer. Next step was setting up and calibrating EMC2. Final step was learning how to create g-code. I spend a huge amount of time trying to find reasonably priced software for this. Maybe there is better stuff now, but I never found anything that seemed any good that wasn't really expensive. I ended up using turbocad to make basic drawings, wrote some utilities to do some of the grunt work of creating the basic g-code from a drawing, and then do a fair amount of hand editing of the g-code.
    In the end, I only spent 300-400 dollars on the entire conversion. So it was a very cost effective route. What I ended up with is very similar to what Sherline later release as their ready made CNC packages. If I were doing it again, I'd think hard about whether I'd just buy their packages, but it does add up to quite a bit of money for both a lathe and and a mill. I also converted my rotary table to CNC, and setup my lathe for threading which is not included in their packages.
    I am interested in what software and process others use for creating g-code. If I could find something that was a lot easier without spending a ton of money on software, I'd consider switching.
    May 2005
    You can create the CNC programs for simple to moderately complex shapes with nothing more than a pocket calculator (with trig functions) and high school knowledge of trigonometry and geometry. An example would be the recent microlight I built in this thread...
    36-21.5-33
    It's not as tough as many who do CNC programming would want you to know.
    36-21.5-33
    Sound like we both ended up at the same place..doing the bulk of our g-code by hand....
    What is your CNC machine setup like?
    Quote Originally Posted by MtbMacgyver
    You should give cambam a try. It's the best 2.5D software I've used in the price range thus far, coming in at $149. The "demo" is actually the full version that gives you a 40 use limit. You can actually stretch that out for an abnormally long time if you never close the application...not that I would suggest that. Link for download is here: http://www.cambam.co.uk/downloads/dw...beta0.9.8i.msi
    Mach3 has come a long way if your last reference of it is from 4 years ago. For the most part, it offers just as much as emc2 unless you get into stuff like rigid tapping. Biggest bonus for me is that it is windows based and I don't need 2 machines to do cad/cam and control. I didn't want to run separate computers if I didn't need to and it works well to create/edit/run on the same machine for me.
    Servos are way overkill on anything smaller then LARGE desktop machines unless you absolutely need a closed loop system. Using a stepper of the appropriate size doesn't hold any draw backs.
    May 2005
    At my job we have some older CNC machines that are used infrequently. I bum a favor off the manufacturing manager for use of one of them after hours. The microlight was cut on a Mori Seiki CNC. The control is a Fanuc
    thanks for all the answers i will look into this more and see what comes out of it
    i would love to have a mill. actually what i really would want is a 6.5m*60*60 cnc that i could cut kayak plugs with.
    the reason for getting a lathe and not a mill is that i have no experience at all with this type of work and i believe a lathe is easier to get started with and is the natural place to start.
    i also believe a lathe would allow me to solve most of the things i would want to do as most t details i would want to get done are round .
    a mill also costs more money.
    i might be wrong?
    Maybe I should look at a mill after all as a cheap alternative to the compound saw. I just spent $136 Aus on a replacement saw blade for the one I killed building the dual DX light. A year ago that wouldn't have been much but it now converts to about $140 US
    Mind you, it is a Japanese steel, 80 tooth, aluminium specific saw blade replacing the 20 year old 40 tooth blade that came with the saw. At that price I even splurged on some cutting wax so hopefully my build quality will step up a notch to reflect the additional cost
    Quote Originally Posted by emu26
    My steel cutting blades for the table saw run $55 USD and remove alot more than 10mm at a time.
    I have used cutting oil but the spray silicone lube seems to give a better surface finish and is much easier to clean up.
    The mill/lathe lights are great and the work/time these guys put into their lights is incredible.
    But I like being in the middle of road on tooling.
    Not a mill/lathe guy, but not using a hacksaw and dremel either.
    Quote Originally Posted by odtexas
    Brand and supplier please, not that I hope to be replacing this one any time soon
    Dewalt
    Or
    Lenox
    Lenox comes in lots of diameters and price with very with diameter. Smaller diameter tend to have less wiggle/deflection when cutting. Table saw can use the smaller diameter blades. The slide miter isn't as flexible though.
    Not trying to derail, but I have.
    Just the same though a table saw and drill press can do alot.
    Plus when I need to cut tonge and groove cedar siding for the house I just change out blades on the table saw and save myself the cost of buying precut siding slats.
