Results 1 to 16 of 16
    build log: 7x xpg light
    Been playing around with a few of the cutter xpg 7up pcb boards and am almost finished with the design.
    Build:
    Cutter XPG407R5-CW
    Driver: taskled maxflex
    Body: t6 aluminum
    Switch: Trick CPI B5000 momentary waterproof remote switch(for mounting on handlebar)
    Battery: gens ace 4000 mah 14.8v 4s1p battery in custom carbon battery holder
    I am waiting for my cable gland and cabling.
    Here are a few pics of the initial build:
    Front:
    Version 2.0:
    I made a second one and handle bar bracket + cerakoted it in blue titanium:
    I fired it up and everything works. Hope to have it together and on my bike tonight.
    Thanks for looking...
    Bigger is better!
    May 2005
    Damn - that's one of the best looking lights I've seen in here.
    Good job!!
    Is it this switch: http://www.globalspec.com/FeaturedPr...s_B5000/1102/0 ?
    Can you post photos of the battery?
    CNC LED light housing for DIY projects
    Reputation: HEY HEY ITS HENDO's Avatar
    Welcome to the forum mmlvmm!
    very nice indeed, and that coating, mmmmmm looks superb!
    ...Scun.thorpe, UK
    May 2005
    Love the look of that coating. Does it hurt the heat dissipation of the light?
    Quote Originally Posted by zemike
    The switch is the bottom one in the pic you posted.
    I am using this battery: http://www.xheli.com/98p-25c-4000-4s1p.html
    It was about the most compact 14.8v 4000 mah I could find.
    I still have to make the battery holder for it...
    Quote Originally Posted by Vancbiker
    The Cerakote-h finish is used on members at cpf and some limited production(expensive) lights. It is extremely thin. Recommended application thickness of Cerakote should be .001". While it doesn't conduct heat as well as non-oxidized metals do, ceramic coatings measured in micrometers are not nearly insulating enough to cause any problems -- otherwise, anodized aluminum would be impractical as a flashlight shell, because anodizing is ceramic.
    Great looking light.
    Will be doing some Gun-kote in the near future.
    A few guys here have used these bake on coatings with good sucess.
    I tend to anodize my lights, but I want to try something new.
    That is a very good looking color. Might have to look into Cerakote in the future.
    That is an awesome mount you came up wiht for you light. Nice work.
    Update:
    I got the cabling done for now and the light is programmed and on the bike. I can't wait for darkness to try it out for an evening ride.
    Here are some pics on the bike:
    CP 5000 waterproof momentary switch:
    Light on high- mid day sun:
    Stopped all the way down:
    The switch is excellent. What was the price for it?
    May 2005
    Love the pic of the garage! Now I don't feel bad about mine.
    I found one cheap at a surplus site on ebay. I think I paid 15 bucks for it. I wish I could find more at that price. The switch is awesome. Just the right amount of tactile click and it is sealed...
    and where did you buy the switch?
    It's not a garage, it's a workshop
    Reputation: gticlay's Avatar
    How do you like the beam pattern? I bought the Polymer lenses and they won't fit over the driver board I chose to use. The lens like yours works fine so I think I'll be using that.
    "It looks flexy"
    Rep Power Infinity +2
    Reputation: brad72's Avatar
    Quote Originally Posted by gticlay
    How do you like the beam pattern? .
    I have made a few 7ups and find the medium optic pretty good as is doesn't have the halo effect that the narrow beam suffers from.
