Results 1 to 5 of 5
    BLT Gamma-Ray SL2-42
    Hi, I'm new to this forum so please be gentle!
    I have a perfectly good set of Gamma-Ray SL2-42 lights but the SLA water bottle battery has now expired. I cannot find a replacement. Is there an alternative power source that would work with these lights e.g Ni-Mh, without altering the bulbs or does anybody know where I can get an original? I'm still running the standard 10w+15w bulbs. I believe these are 4.8v? I cannot find a contact email @ BLT or Norco (the parent company) and the UK importer Windwave say they no longer import. Anybody out there that can help me?
    I'm in the UK.
    Thanks,
    .Richard
    Reputation: HEY HEY ITS HENDO's Avatar
    you in UK??
    try ebay for a new SLA battery
    ....http://cgi.ebay.co.uk/6V-4Ah-sealed-lead-acid-battery
    ............ £6.99 including postage
    EDIT... 10w+15w =25w@6v=4Amps .... what capacity was the original?
    ...Scun.thorpe, UK
    Hi,
    Thanks for your reply. I've just split open the waterbottle and it's a 6v 5ah. non-standard size for sure. I'm going to go for:
    http://cgi.ebay.co.uk/6V-5Ah-sealed-...d=p3911.c0.m14
    I guess 5ah gives longer burn time. This shape will be easier to make a container for too.
    Seem ok?
    yep that`ll do nicely, and this will be the cheapest solution to the problem,
    ........ stick around Ric, i know it wont be long before you`ll go LED
    ..............................nobody, can resist the lure
    ...Scun.thorpe, UK
    Great - thanks again for you help- battery ordered.
    I've just looked at your video of the LED's - very impressive.
