Results 1 to 3 of 3
    Bikelight PVC pipe housing question
    Hi All
    Few weeks ago there is a post to show how to built a bikelight housing by PVC pipe, anyone can show me the thread will be highly appreciated.
    Thanks in advance.
    Spanish biker
    Reputation: msxtr's Avatar
    Hi, look this link sure that help you
    Here
    Greetings - Saludos
    msxtr
    Warning!!! my english is very very bad, sorry.
    Easy DIY led light1
    Easy DIY led light2
    The Beast!!!
    I would go with either aluminum or copper as a housing material. PVC does not conduct heat away from the LEDs very well at all... in fact it traps heat inside. Two popular designs are the copper end cap design and the square aluminum tubing design that I've had good luck with. Search around this site and you can find a good deal of info on both designs as well as a few other ingenious solutions.
