Results 1 to 5 of 5
    bFlex Programming Problem
    Hey Everyone,
    Long time lurker here with a bit of a newbie question in regards to programming my bFlex.
    I'm can't seem to disable the duomode and put it in mutlimode... In section 8.3 you're supposed to click 4 times to disable duomode and enable multimode, only there isn't a 4th click, on the 4th click it returns to L1 (dim), rather than going to multimode (main led off)...
    Am I missing something obvious here? I tried searching the boards but couldn't find anything...
    Thanks in advance!
    -Pat
    Reputation: znomit's Avatar
    Quote Originally Posted by ptgerke
    Hey Everyone,
    Thanks in advance!
    -Pat
    Make sure you have the correct model bflex
    I just purchased it weeks ago. The color and silkscreen match the most current version on the website, and there's only one option when purchasing, right?
    It sounds like you're using the V1.1 manual instead of the latest V2 manual. With the latest bflex, you set Duomode, Threemode, Trimode, or Multimode in section 8.13. 8.3 only sets the levels and only goes through 3 clicks.
    thanks Macgyver! for some reason I downloaded the wrong version of the manual... told you it was a newb question... Thanks for your help guys!
