Results 1 to 7 of 7
    Bflex/B2flex terminal positions
    Can anyone give me a CAD drawing or diagram showing the positions of the terminals on the old Bflex and newer B2flex drivers? I am particularly interested in the LED connections.
    My housing has a 26mm recess for the board and I want to drill through so the LED wires enter the board from behind in the right place. However I also need the holes to miss the stars on the other side, so I need to be accurate.
    I tried measuring the board but attempt 1 missed by a few mm. Thanks to bendy silicone wire I can get away with the mistake but before I make another I thought I'd ask if anyone already had the correct dim's.
    George, this info would be helpful for all of your boards. I don't need the component layout but the positions of the terminals would be useful.
    Jez
    Reputation: BrianMc's Avatar
    Can you use the images on the web pages and size/cut & paste them? The older bflex pictures are under history tab.
    If not, contact George through Taskled.com contact link. He is great!
    Quote Originally Posted by BrianMc
    Didn't think of cutting out the image. I'll try that and drop George an email.
    Cheers Brian
    http://www.taskled.com/techb2flex.html has x/y position info now. I'll add the info to the other drivers over the weekend.
    cheers,
    george.
    Quote Originally Posted by georges80
    cheers,
    george.
    Perfect! Thanks for such a fast response George
    http://www.taskled.com/techbflex.html has the info for the bflex driver.
    cheers,
    george.
    Thanks George, that's just what I needed. I am planning to thermal epoxy the bflex face down to the heatsink so I must remember to reverse the dimensions!
