Results 1 to 9 of 9
    Mar 2015
    Best cold weather 18650ís
    What 18650 batteries have you guys had the best luck with in cold weather? Also, where do I get them? There are so many options out there and so many have crazy mAh ratings.
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    there really are no differences in lithium ion, cold affects them the same
    best you can do is buy top notch ones..
    panasonic/sanyo (NCR), lg, or samsung are the top players
    avoid others.
    #1 just do not charge a cold lithium, let it warm up to at least 40 deg or higher
    before slapping a charger on it, or kiss that thing goodbye if you try to charge a frozen (32 deg or lower) cell
    max mah possible is 3600mah (3545 nominal) but unless your driver
    is developed for the specific call, max mah doesn't always mean more runtime at a specific brightness. sometimes a pack of 2800mah can outrun a pack of 3400's it depends on the 'discharge curve' and some lower mah cells tend to stay higher volts in the mid-range of their runtime and some drivers respond better to that.
    drivers may see the steep initial drop of volts on a 3400 or 3600 as a sign the battery is depleting and it won't run at max brightness as long as a 2800 would, or will indicate as low battery really soon, but will stay on low battery for a long time
    anyhow, 3600 max, and cold affects them all about equal.
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
    Light freak
    Reputation: scar's Avatar
    Jun 2005
    Avoid E-Bay!!!!
    Mar 2015
    perfect. This was what i was looking for. Is there a online retailer that has a good track record?
    EAT MORE GRIME
    Nov 2013
    Quote Originally Posted by Jefflinde View Post
    battery junction is my go to...
    https://www.batteryjunction.com/
    all 18650 they sell have top notch guts.
    orbitronic, nitecore, klarus, olight, these are special by the brand which makes the wrapper and protection circuit, but they contain high end core cells inside.
    the olight 3600's have been rock solid for me
    the ultrafire name is usually poison anywhere, except on this site,
    as true ultrafires are fine cells. but there are so many fakes,
    usually anything with the name *fire is garbage. but not from
    here and not actual ultrafires...they are good.
    Light freak
    Jun 2005
    I have used BatterySpace.com with great results. Batteryjunction should be good also. I have found that batteryspace does not build their packs up in advance and have them setting on a shelf for months. Feels like they build them to order.
    Dec 2005
    Perhaps I can piggyback on this forum. I have left my 18650 set to long and cannot get it to take a charge. Looking for new cells x 4. Protected or unprotected??? Huge difference in cost.
    EAT MORE GRIME
    Nov 2013
    unprotected is fine if your light handles over-discharge prevention
    so, see what the manual says about the light or the driver in the light
    Dec 2013
    You need a battery heater, fastech vapor wire is good, I got some but using it for clothing this winter.
    Fiber Tow I think is the technical term, or just any thin wire will heat up too. But be 110% sure you dont cook the 18650!!!!
  1. Onyx in COLD weather? Good cold weather hubs?
    By car bone in forum Wheels and Tires
    Last Post: 02-11-2016, 04:23 PM
  2. cold weather riding - how cold do you ride?
    By overmodulated in forum Massachusetts
    Last Post: 12-27-2014, 10:43 AM
  3. Replies: 70
    Last Post: 12-15-2011, 04:05 PM
  4. Cold weather apparel. What are you wearing for the cold rides?
    By masterlucasdude in forum Apparel and Protection
    Last Post: 08-10-2011, 06:42 PM
Members who have read this thread: 48
