Results 1 to 23 of 23
    Smile been at it again single xm-l cuby
    been at it again single xm-l 2.8mah 3 mode kd driver with a dx 18mm reflector.
    cheers thwang
    A waste of time it is is
    Reputation: emu26's Avatar
    Looking good Thwang, any beam shots of that reflector and the xml yet?
    hi
    not yet hopefully by the weekend.
    thwang
    Dirt Deviant
    Reputation: savagemann's Avatar
    Thwang, is that the smooth reflector, or the OP version?
    I have the OP version, and it has a great beam with the XML.
    I have about 20 of them that are going into lights for riding buddies.
    Great deal on them. Especially if you buy them in BULKRATE pricing. If you buy 5 of the 4 packs, they come out to $1.16 each shipped. Absolutely a steal for an aluminum reflector.......as long as you don't mind waiting a month for them....= )
    Here is a link to the ones I got..........
    http://www.dealextreme.com/p/18mm-12...s-4-pack-14598
    Look, whatever happens, don't fight the mountain.
    hi savageman
    its the op hopefully i will get it finished this weekend
    That does look nice. I look forward to seeing a beam shot.
    What kind of mount is that?
    Mar 2011
    What type of switch are you using? I am building a single xm-l light with the same board, but have no idea on the type of switch to use.
    hi
    im useing a momentory switch.
    thwang
    Vroom I'm pretty sure the mount is a cateye one, it certainly looks similar to what use.
    hi
    it is a cat eye.
    thwang
    finished beam shots latter but saying that the dx reflectors are quite floody so i might have to mod one or try a regina.
    thwang
    Dirt Deviant
    COOL!!!!
    Looking good dude.
    I like it!!
    Looks killer.
    The recess of the back plate was a nice touch.
    Great job making that old minimill work a treat .
    did you get the gears sorted out or still using it on slow speed .
    cheers chaps
    still on slow for now
    nice looking light. the cateye mount on backwards?
    hi
    mounts the right way i think you clip it on front to back.
    thwang
    you can run it whichever way you want to, front to back, back to front. You might even be able to run it side ways, though you probably wouldn't want to
    Do It Yourself
    Reputation: Homebrew's Avatar
    Nice work! They have a shorter version of the Judco switch that would look better with lower profile (same one as scar's Amoeba). I have the same one you do and the tall rubber boot ruin the aesthetics for me. But my light is just an ugly but functional 1" square tube jobby. Your light deserves better.
    Long Live Long Rides
    hi homebrew
    its what i had in the parts bin mk11 will have a dome switch.
    thwang
    Quote Originally Posted by mattthemuppet
    lol mat
    beam shot very floody not my cup of tea but i didnt put a spacer between the pcb and the reflector. tried a xp-e optis didnt like that so next is to buy a couple of regines and try them.
    thwang
    You should set it on your bench and slowly raise the reflector off of the LED to see if it makes a beam pattern your happy with. I know on some reflectors you need to space them off of the pcb.
