Results 1 to 6 of 6
    Reputation: friz's Avatar
    Dec 2012
    Battery connectors?
    I have a couple Magicshine knock offs that I am happy with but they have different connectors. Does anyone have a P/N for plugs that are the actual size that Magicshine uses so I can make my lights function with Magicshine accessories?
    Reputation: beecrazy's Avatar
    Action LED has an extension cable you can purchase. They are located in the states.
    Cut the end off an splice!
    09 Specialized Rockhopper Comp 29er
    16 Rocky Mountain Blizzard -30
    Ditto on the Action LED Lights website. Just be careful - some of the Magicshine clones these days aren't using the same 7.2/8.4V pack that the MS lights use. Some are now running 4cell packs wired in parallel . Check your batteries on a voltmeter before swapping around.
    For a hair less money and a whole lot longer a wait, dx dot com has sku 32751.
    The study du jour: can one's reputation be artificially inflated by simply putting a request for rep in one's sig?
    Dec 2012
    Thanks guys. I'll probably get a mix of the cords and the connectors coming to give me more options.
    Also - If you didn't want to cut and splice the connectors that are on your current packs and light heads, you could always make yourself a couple of "gender-changer" style adaptors, say like 3" long that had the proper end on each end for whatever combinations you were trying to combine.
  1. Source for Lupine Plugs / Connectors
    By architectx in forum Lights DIY - Do It Yourself
    Last Post: 11-05-2013, 11:46 PM
  2. Best Connectors
    By Coldass in forum Lights DIY - Do It Yourself
    Last Post: 10-28-2011, 04:34 PM
  3. Replies: 0
    Last Post: 04-09-2011, 07:17 AM
  4. Get your cable and connectors here!
    By piesoup in forum Lights DIY - Do It Yourself
    Last Post: 03-21-2011, 11:24 AM
  5. Right angle connectors?
    By KBARK in forum Lights DIY - Do It Yourself
    Last Post: 03-08-2011, 09:00 AM
