Results 1 to 3 of 3
    basic power consumption question
    This is not a light build but I know you guys can answer the question :-)
    I have a 12VDC fan that draws .15A or 150mA. If I run in series 4 x 3.2v 18650 2400mAH batteries to power the fan. Will I be able to power the fan for 9600mAH / 150ma = 64 hours?
    Thanks,
    David
    May 2005
    Nope. Your battery will only still have 2400mAh capacity because they are series connected. About 16 hours run.
    ah... yes... I should have known that..
