Results 1 to 47 of 47
    AYUP problem and possible solution
    someone sent me a set of Ayups to have a look at as they had gone very dim
    they originaly thought it was the battery but on replaceing the battery the problem was still there .
    so after a fair bit of head scratching wondering how to get into the damn things when I did there was a strong smell of burnt electics .
    most of the wireing was a charred mess with the bare minimum connecting it all together and upon disasembly it just crumbled to nothing
    the only thing left was the resistor above .
    the leds were toast too but did emit a small amount of lumens when tested.
    What I have done is slot in 2 XPEs and Regina reflectors but need to drive them somehow
    this I have not yet decided on .
    but as I tested it on the power supply @ 1000ma drive the 2 heads did get very warm
    Does anyone know what current an Ayup is supposed to run at and what value is the resistor they use .
    for future reference to mod old ayups the driver on board single xpg optimised for the Regina would be a good implant
    pic of the modded Ayup
    Reputation: zen bicycle's Avatar
    They did a direct drive with the original battery pack at about 600ma as I recall. Don't hold me to it though.
    Quote Originally Posted by zen bicycle
    Cheers Zen that sort of makes sense as tested at that and they stay pretty cool .
    but we all know that when it comes to modding lights we want it all not 66%
    I think on a normal dark night in the uk it will be ok at 1 amp I hope
    main problem is there is nowhere to put a driver
    In later models Auyp put the driver in the battery pack, so there was never supposed to be a driver in those things. Maybe a cord mounted bflex in a small case on the cord just behind the lights?
    Yes that was my thoughts I have some of the cheap 960ma drivers from the ebay guy
    may do that with one .
    I have just been out walking the dog with it cobbled to a battery and 1 amp driver with no heat problems at all just luke warm
    I am thinking the owner will be very happy with it
    A waste of time it is is
    Reputation: emu26's Avatar
    Are you going to share how you got it apart in a condition that could be put back together?
    Lots of my mates here would be very interested in knowing that
    Those ebay drivers, are you using the dimmed version or did you get the ones where you put the resistor in to suit your desired level? Just asking to see if you are still getting the very little noticeable difference between the 50% power and full power we spoke about before
    Randomhead
    ok, for some reason I feel compelled to ask which ebay guy we're talking about
    This one
    Quote Originally Posted by emu26
    Ha I should have taken photo`s as now it is reassembled rather permanantly .
    the front is a nylon ring which compresses a silicon rubber seal on to the optic it just snaps in and it quite difficult to remove without damage .
    I warmed the light up to just holdable and it made it flexible enough to get a sharp small screwdriver under the lip and lever it out with a small amount of damage to the ring
    then the silicon seal is easy and the rest just pulls out . the led star was just sitting on the heat sink and no compound .
    to pull the heads off was a riddle but the easy way I discovered was when you turn the heads they come to a stop just turnd it a little past the stop and then pull and the head unclicks .
    and pulls away there is some length on the wires inside but if it comes with a jerk you may pull the wires out and break them so a little care here is needed .
    2 orings on each end seal the light and did disintegrate on this one which is why it is now sealed with the faithfull silicon and no longer adjustable
    Reference the driver
    it is dimable but I will just do it as a single power so no switch needed to keep it cheap .
    no reassembly the regina and 20 mm star fit perfectly
    but I had to leave out the seal and use silicon and then click the nylon ring back in but did need to cut 2 x1 mm plastic lens covers
    from a welding mask cover any thicker and the nylon ring would not fit .
    but I guess if you were good with the silicon you could just use that
    and I did put some thermal paste in
    Cheers mate, thanks for the reply
    May 2005
    Quote Originally Posted by troutie-mtb
    the led star was just sitting on the heat sink and no compound.
    A little surprised they would skip such an inexpensive performance and longevity enhancing detail.
    Nice work Troutie.
    I wonder how many have thrown these away and can now see what can be done to resurect them.
    Any chance of a beamshot? shame you hadnt got a working Ay-Up to compare it against.
    He'll be well happy with that, well done
    Light freak
    Reputation: scar's Avatar
    Jun 2005
    Troutie, maybe he just needed to run one of these heatsinks
    Currently muddy
    This is a very timely thread. A busted Ayup just made it's way to me and I was considering a dual xp-g regina build.... hmmm. Unfortunately the previous owner cut the nylon snap rings trying to take the thing apart.
    Out of curiousity, how did you go about removing the jack? Seems to be sealed in there with copious amounts of glue.
    Thanks for all the detailed information, it's very helpful.
    Quote Originally Posted by emptyvoxel
    Brute force and it is non replaceable but a new one will glue in place
    you dont really need the nylon ring if you can be good with the silly cone
    Don't use the cone that comes with the silicone tube.
    Go to your local chemist / pharmacist (depending on where you live) and buy a 5 or 10 ml syringe. The end of the syringe normally has a small "nipple" on it, cut this at about a 60` angle. Pull the plunger out of the syringe. fill the syringe about 3/4 full with silicone. Replace the plunger and now use the syringe to accurately apply the silicon where you want it, first time.
    When you have finished, squeeze out all of the silicone from the syringe. Get a small container and put some kero in it then just suck the kero up into the syringe, push it out and do this a couple of times. this will dissolve the silicone and leave the syringe clean for the next use.
    I pulled my ayups apart last year [ 1 y/o at that stage ] to replace the leds, got one apart ok but trashed the plastic rings on the other. to replace them I used some silicone orings that were slightly bigger than the ID of the lamp body and a ptfe backup ring. takes a little bit of manipulation but they snap into place nicely enough. the a quick chamfer of the backup to make it look pretty.
    the pics show the original parts laid out and the oring replacement in their new home
    if you're careful with a pair of pliers, by gently squeezing around lamp socket you can crack the glue and pull the end of the plug out.
    the socket itself is just the business end of a 2.1mm female dc plug. ( don't get the metal ended ones though, they don't work ) plastic surround type only.
    Attached Thumbnails Attached Thumbnails AYUP problem and possible solution-dsc00036-small-.jpg
    Currently muddy
    This thread is fantastic, thanks for all the tips.
    Ok now had the chance to do a like for like comparison .
    I got sent 2 fully working Ayups yesterday .
    so replaced the leds and optics with XPGs and Reginas in what was a pretty easy swop .
    this left me with one standard and one Ay-upgrade
    beam shots
    Standard Ayup
    Ay-upgrade
    the standard Ayup is drawing from an 8 volt supply and taking 410 Ma
    the Ay-upgrade is drawing 600 ma .
    I have only changed the leds not touched the resistor
    so why the extra draw from what should be more efficient leds
    is it to do with the lower VF of the XPGs .
    not measured anything yey but will do when I do the second one
    Yes, It's due to the lower Vf of the XPG as compared to the XR-E. And as a result the LEDs are actually drawing more power. If they are using a simple resistor to regulate the current, then you'll need to swap out the resistor when you change to LEDs with a different Vf if you want to keep the power to the LED approximately the same. Otherwise, it's not really a fair comparison since you're actually driving the new LEDs at a higher power levels.
    You said you were testing at 8V, I don't know the battery voltage of a standard Ayup setup, but if it's much higher than 8V, the LEDs will be running at really high power levels and will probably overheat without a resistor swap.
    Cheers MtbMacgyver
    Agree its not like for like but then you dont want to mod something and it be the same
    output .
    so for an easy upgrade it seems a nice result for those with aging Ayups .
    the battery is a 2S li ion and well underdriving the leds .
    changing the resistor is not an easy task due to the copious use of epoxy
    and the inaccessability of where it is .
    had it running in still air on my washing line with an ambient of 9 c and it stabilised at about 18 c and sat there for over an hour with no increase in heat .
    so in my opinion
    ease of mod
    cost of mod
    end result
    all get a
    Nice work chris.
    Can we keep this thread quiet though, I don't want all my mates with ageing Ay-Ups to get any ideas, just want them to throw away their redundant lights, my way
    Cheers MtbMacgyver
    output .
    so in my opinion
    ease of mod
    cost of mod
    end result
    all get a
    Wasn't trying to imply it wasn't a good mod. I just didn't know enough about the Ayup setup to know what the final drive current would end up being. Sounds like they are so under driven that actually having it increase some is likely a good thing. This is increasing the power dissipation in the resistor by a small amount, but resistors will typically stand up to a fair amount of abuse so it'll only be an issue if it was already badly under spec'ed.
    Quote Originally Posted by MtbMacgyver
    Any chance you could explain this direct drive thingy I dont remember ever seeing it discused on here before .
    I had a look over on CPF but every thing I saw assumed you knew what you were doing .
    Troutie,
    The value of the resistor is pretty easy to work out, just subtract the total forward voltage of the LEDís from the voltage of the battery pack - So for 2 LEDís with Vf in series of 3.3 the total Vf is 6.6v (easy so far!); Take this away from 7.6v (nominal batter pack voltage) to give 1v
    To get 1 amp flowing in the LEDís just use V=IR ... which in this case is pretty easy as v=1, I=1 so R.... you guessed it equals 1 ohm! And as 1 amp is being dissipated at 1v it needs to be a 1 watt resistor.
    There is a great little calculator here: http://led.linear1.org/led.wiz
    That said I have been direct driving (ie with no resistor) a pair of Seoul P4's from a 7.6v lithium pack for a couple of seasons now and it makes a good small helmet light.
    Despite the dire warnings of meltdown and LEDís going pop, my set (and the 10 or so similar sets that the guys I ride with) all have kept going strongly with no problems.
    I started out by using a 1 ohm resistor but in reality I was only getting something like 700mA so I took it out and just run the 2 LEDís directly from the battery and like I say no issues so far.
    I do have a low setting on the light which uses a 5 ohm resistor giving about 200mA just for battery conservation Ė I havenít got a photo to hand but will post some after the weekend.
    I have been playing around with direct driving 2 XPGís and without a resistor they run at about 1.2A which might be a little high, but I think I will try a pair of those for a while just to see what happens.
    Thanks Tanner72
    so let me get this right you can just connect up 2 XP e/g s to a 2s li ion battery pack
    with out them going pop even fresh off the charger .
    and they will run at about 1.2 amps .
    I guess they then dim as the battery drains .
    now goes away to try and kill an xpe led
    Well thats what I have been doing with the P4's for some time without any trouble!
    I tried it briefly with a pair of XPG's to measure the current draw but I will be getting a set together to run over the winter just to see what happens....
    Let me know how you get on, but like I said there were a lot of dire warnings about blowing LED's when I first did it but to date nothing has gone pop!
    I just nervously connected 2 XPGs to a 7.5 volt battery and meter they didnt die
    but the current through them was 2.4 amps
    tried the same with 2 XREs out of an Ayup and they had just under an amp current .
    the vf of the xres is 7.5 volts as the xpgs was 6.6 volts
    so would I be right in thinking that for a basic 2 led light all we would need is a couple of resistors and a switch to give us hi and low power settings .
    Please forgive the questions here also what if 4 leds in a 2s 2p con fig .
    would they then have got half the 2.4 amps each .
    Reputation: Ofroad'bent's Avatar
    Do I sense a Troutie version of the Ay-ups coming up?
    2 XP-Gs with Reginas and a high/low setting in tiny housings?
    2.4A - Eek!
    I am highly surprised that there is such a massive difference between the two different LED's and itís exactly twice the current I measured with the XPG's - they were in series? (sorry to ask the obvious)!
    Yes for a basic light all I used initially was an ultra miniature 3 position toggle switch and 2 resistors.
    Iíll take some pics when I get home and stick them on here.
    It does rather sound like there is a 'Trout-up' coming!
    Keep in mind that wires are resistors and current meters are even bigger resistors. So when direct driving the actual current can change significantly with changes in the wiring or when you remove a meter from the circuit. It can be difficult to measure the current of a direct drive setup because the reistance of inserting a meter can drop the current by a large amount. You also have to keep in mind that battery voltage drops as current goes up. So the current for a direct drive will settle at the point where Vf of the LEDs plus reistive voltage drop in the wiring match up with the voltage/current graph of the battery. There is nothing wrong with direct drive other than it tends to be a pretty touchy setup and the current can change pretty significantly with temp, battery voltages, battery and LED variations.
    Quote Originally Posted by tanner72
    2.4A - Eek!
    Yep series Xpgs
    the battery is a 4 cell 7.4 volt Li ion pack if that makes any difference .
    I also tried them on the bench power supply slowly turning up the voltage
    and when I got to 8 volts the leds started smoking ( they were on a large lump of heatsink ) and the amps had gone 2.5 maps
    so rapidly turned it back down .
    Hmmm might be something to do with the pack size?
    I use a 2 cell 7.4v pack.
    The first photo shows the pack fresh off the charger direct driving a pair of XPG's at 1.3A - the question is how accurate is my toy town meter! I will rig up a Max or B Flex and check it against a known drive current this weekend.
    The other pics are of my head lamps ( - I hope you don't think I am hijacking the thread! )
    The silver one was my first attempt - it has a one ohm resistor and a five ohm resistor selected by the toggle switch with the middle position being off.
    The blue one is MK2 I took out the one ohm and it direct drives on high and uses the five ohm on low.
    Both use the Seoul P4 which from memory give 220lm each at 1 amp.
    Attached Thumbnails Attached Thumbnails AYUP problem and possible solution-img00250-20101015-1815.jpg
    Reputation: bwack's Avatar
    The matching of the voltage/current graph makes me think that, If you connect two leds directly to a 2Cell battery, it is crucial that the battery must not have too low resistance (steep voltage/current slope). So if you choose a big battery, say 2S10P will give you a very flat voltage/current slope, and the leds will likely burn off before that happens ? makes sense right= more cells, lower inner resistance, less ballast for the leds... I'm sure just a small ballast (resistor) would keep the current at bay compared to not having any at all..
    OK will give it a try with a 2 cell pack and see if it is different .
    managed to find some resistors but only .6 watt ones and wow they get pretty hot
    I shouldnt really have grabbed hold of it .
    Well Have I got real good batteries cos just tried a 2 cell pack and it went to 3 amps and a little magic smoke escaped from the leds .
    but not enough to stop the poor leds from working yet.
    If you have several .6W resistors you can connect them 2s2p and the resistance will be the same but they will take 1.2W instead.
    Quote Originally Posted by xyz-saft
    Thanks I just tried that still got a bit warm but not flesh burning hot.
    so would I be correct in thinking you would need to heat sink the resistor
    as it would be inside a housing .
    It wouldn't hurt - I just made sure they were in good contact with the body.
    You could use one of these kind which allow you to fix them to a sink using the hole:
    May 2005
    If the meter was removed from the circuit, the current draw through the LEDs would increase. When you use the current setting on a multimeter, you are inserting a low ohm resistor in the circuit. The meter just measures the voltage drop across its internal resistor to calculate and display the current flow. Works fine for most measurements but gives misleading results when measuring devices that have very steep voltage to current curves like LEDs. Use a current clamp type meter to get slightly more accurate measurements. Take two turns of wire through the meter jaws and divide the reading by two to get a little better resolution at low currents.
    edit: fixed spelling and clean up some grammar
    Reputation: uncle_bob's Avatar
    Thank you
    Found this tread the other day and thought in stead of sending my 2008 Ayups in to get upgraded I might give it a go myself.
    I then ventured onto the Cutter sight purchased the appropriate Led (xpg x2) and some Regina reflectors, they are great to deal with by the way.
    Meandered into JayCar bought some 1W 1 Ohm resistors, one for each light, dug out my trusty soldering iron and got to work.
    I must say after little effort and no knowledge, except that skimmed from the post here, they came up a treat. They get a bit warm standing still, but should be fine when moving.
    Thank you for the great information, it gives newbs like me the ability to create better lights for less. Only problem is that I think I may get hooked on lights now, I have decided to fix a nonfunctioning Nightflux light too.
    I also have a mate with a lathe so stay tuned. It may not be pretty but at least it will be bright.
    Very interested in this direct drive method for a small rear light (this a clip-on red reflector of some sort) running in low ~200mA, which could be run on high for a helmet light (remove red reflector).
    But would it be possible to incorporate a simple flasher circuit (like the 1000's of curcuit on the web for running the 5mm low power LED) or will these burnout quickly when run with XPG's. was thinking of using 3-4 AA Nimh with a single XPG
    Ok, for those interested, I took some beam shots of my modded ayups.
    1. XPG R5 Regina with standard resistor ( forgot to look at the colours, so don't know the value)
    2. XPG R5 Regina with 1w 1ohm resistor ( runs a little hotter and brighter but not hot enough to worry about)
    3. Standard Ayup: XRE Medium optic.
    Water bottles are at 10 metre intervals.
    Hope this helps anyone wanting to upgrade their own.
    cheers
    Simon
    Attached Thumbnails Attached Thumbnails AYUP problem and possible solution-img_0453.jpg
    Team Awesome
    Reputation: playpunk's Avatar
    Mar 2005
    Has anyone done a mod like this more recently? I have some 09 aayups I want to mod.
    Sep 2004
    Me to but will need some instructions, and a list of bits
    ay-up upgrade, have you contacted them?
    Sep 2004
    Already had the upgade done, not that much different in my opinion. Really shows with other lights around they just dont cut it anymore.
