The Cree XLamp ML-C LED brings lighting-class performance to 1/3-watt LEDs and continues Cree's history of leading-edge innovation in LEDs for lighting applications. The XLamp ML-C LED brings high performance and a smooth look to a wide range of lighting applications, including linear lighting, LED replacement lamps, fluorescent retrofits and retail-display lighting.
The ML-C LED is available in parallel and series as well minimum 80, 85 and 90-CRI options for a wide range of color temperatures. With a typical forward voltage of 6.4 V at 50 mA, ML-C series LEDs provide a high-voltage option that can enable a driver that is cheaper, more efficient and smaller in size to lower system cost. The minimum-80, 85 and 90 CRI ML-C LEDs enable customers to address applications, such as retail and restaurant lighting, where high CRI is required.
Documentation
Title
Version
Last Updated
PDF
Data sheet
0
March 20, 2012
Binning & Labeling
4
March 20, 2012
The Cree XLamp ML-E LED brings lighting-class performance to 1/2-watt LEDs and continues Cree’s history of leading-edge innovation in LEDs for lighting applications. The XLamp ML-E LED brings high performance and a smooth look to a wide range of lighting applications, including linear lighting, LED replacement lamps, fluorescent retrofits and retail-display lighting.
XLamp ML-E LEDs are now available in series and color options. With a typical voltage of 9.6 V, the XLamp ML-E series LED can enable the use of more efficient, smaller drivers to lower cost for applications such as LED replacement lamps. Minimum-80, 85 and 90 CRI options are available for the ML –E White LED to address applications, such as retail and restaurant lighting, where high CRI is required. Available in red, blue and green, ML-E Color LEDs allow customers to address a broad set of applications including architectural, hospitality, restaurants, emergency-vehicle and decorative lighting
Documentation
Title
Version
Last Updated
PDF
Data sheet
4
March 20, 2012
Binning & Labeling
4
March 20, 2012
PRODUCT ANNOUNCEMENTS
XLamp® ML-C LED
Features
Efficacy of over 114 lm/W (cool white)
Available in ANSI-binned white (2,800 K to 8,300 K)
Wide viewing angle: 120°
3.5 mm x 3.5 mm package
High voltage and minimum 80-CRI options
XLamp® ML-E LED
Features
Efficacy of over 129 lm/W (cool white)
Wide viewing angle: 120° - 125°
Series and parallel options
6000 hours of LM-80 data available now
Colors: red, blue green
Lighting Applications
T5/T8 bulbs; fluorescent replacement
Under-cabinet lighting
Retail and refrigerated display
Panel lights
Aisle, step and pathway lighting
Hospitality including restaurants, bars, cove lighting, theaters and museums
Color linear lighting
Emergency vehicle lighting
Documentation
Title
Version
Last Updated
Data sheet
0
March 20, 2012
Binning & Labeling
4
March 20, 2012
Documentation
Title
Version
Last Updated
Data sheet
4
March 20, 2012
Binning & Labeling
4
March 20, 2012
XLamp® ML-C LED
Features
XLamp® ML-E LED
Features
Panel lights
