    anyone see the eliptical optics in operation?
    Thinking of building a twin xml l2 bar light. Has anyone had any luck with elliptical optics? On paper it seems to be a good idea with a mix of flood and a bit of narrow.
    10003-L25 Elliptical Lens - LED Supply.com
    I guess they are cheap enough to just buy a few and try it out.
    After reading some specs, it seems I am mistaken. When I saw the 44*x12* I assumed a pear shaped pattern. like nice and wide in the front but with a bit of throw.
    Am I right it saying that it is more of a horizontal "bar" like beam?
    May 2005
    Quote Originally Posted by machine4321 View Post
    I have not tried the exact optic you linked, but the one I played with (for an MC-E) made an oval shaped beam. Since I don't like much flood, I thought about using it turned 90 degrees from "normal". All it did in that orientation was put too much light close in or do a good job lighting up the trees depending on the aim.
    I will pass on them. I have used the 20mm optics from led supply in my last build (copy of puckedups) and they work pretty good but, I have not tried anyone else.
    they have some 26mm as well but im not sure I will like the frosted.
  1. Operation Fox DHX5 Air Bleed
    By EmanResu in forum Shocks and Suspension
    Last Post: 10-24-2014, 12:01 PM
  2. Operation Name Change
    By CHUM in forum Off Camber (off topic)
    Last Post: 04-06-2013, 07:58 PM
  3. Rockshox Monarch Rt operation(?)
    By ccaddy in forum Rocky Mountain
    Last Post: 10-23-2012, 06:13 PM
  4. Talas operation question?
    By TheNormsk in forum Shocks and Suspension
    Last Post: 06-20-2012, 07:11 AM
  5. Bike Thief Sting Operation
    By fatcat in forum California - Socal
    Last Post: 12-23-2011, 09:18 PM
