Results 1 to 2 of 2
    Reputation: gticlay's Avatar
    Anyone run an MCE at 100% in easy2led body?
    Want to make a longer throw light, running my MCE in it at 700ma. I know it'll run a bit hot but was wondering just how hot with all those fins on the easy2led. Lemme know if you have tried it!
    Clayton
    "It looks flexy"
    May 2005
    Quote Originally Posted by gticlay View Post
    Clayton
    Haven't tried it, but you will not get any decent throw out of an MCE unless you use a Fraen narrow reflector or a Ledil Iris optic. Those are 32mm and 35mm diameter. Will that fit the easy2led?
    First MCE light I built used a Carclo 20mm "spot" optic. It was so bad, I never even put it on the bike, not worth the effort to make a mount.
