Results 1 to 2 of 2
    Anyone own a Specialized Astro 5.0 headlight?
    I can't find my charger. The unit is discontinued, and when I contacted the manufacturer they told me they no longer have the specs. Adapter for charging NiMh battery. The unit is sealed and I can't take the battery out without breaking the casing.
    So......if anyone has this unit, could you tell me the specs on the power adapter for rechargeing?
    I need to know output voltage and milliamp rating.
    If I try any old adapter I may start a fire.
    Thank you for any help in this matter
    Specialized Astro 5.0 Headlight
    I have an Astro 5.0
    The charger specs are output 9 volts @ 200 mA
    The pin on the plug is negative on the outside, positive on the inside and has these
    dimensions, length of pin is 0.280 inches, the outer diameter is 0.135 inches and the
    inner diameter (size of the hole) is 0.052 inches.
    I can't find the handlebar mount, do you have an extra or know where I could get one.
    Thanks, Wayne V.
